Amica FK200.4 Refrigerator: LED Lighting Issue, SMD Diodes, F1 Legs, Capacitors, Troubleshooting
gorylla 18438 6
  • Suspected capacitor fault in refrigerator LED board
    #1 19684948
    gorylla
    Rate: 33
    I have an Amica refrigerator, quite new, in which the LED lamp was damaged. To my surprise, there is a plate with SMD diodes under the shade. I wanted to order a new board, but there is no availability in Poland, and the price in England, for example, is 18 pounds plus shipping, it's a joke. So I decided to fix the LED.
    Electronic board with HJC 1.0 µFK MKP-X2 capacitor on a yellow base. LED board for Amica fridge with SMD components and a capacitor.
    This is what it looks like. The first thought is to disconnect the refrigerator and check on the F1 legs if I have a passage, but there is no passage. I thought to myself, ok. now I set the meter to 230 V and turned on the power to the refrigerator. To my surprise, after applying the meter to the legs again, the voltage of 230 V appeared and the LEDs came to life, they shone normally. Which of the components could be damaged and what to check next?
    Did one of the capacitors lose its capacitance and I excited the LED through the meter and its capacitance?
  • #2 19685097
  • #3 19685139
    DiZMar
    Help: 2894
    Rate: 6674
    Anyway, I have access to this module at a decent price with delivery from Poland in 1-2 business days.
    Amica FK200.4 Refrigerator: LED Lighting Issue, SMD Diodes, F1 Legs, Capacitors, Troubleshooting Amica FK200.4 Refrigerator: LED Lighting Issue, SMD Diodes, F1 Legs, Capacitors, Troubleshooting Amica FK200.4 Refrigerator: LED Lighting Issue, SMD Diodes, F1 Legs, Capacitors, Troubleshooting
    Like writing something on PM.
    32038456
  • #4 19685183
    HD-VIDEO
    Help: 1265
    Rate: 1887
    Cold February on the fuse, solder it.
  • #5 19685280
    gorylla
    Rate: 33
    Okay, first I'll try to correct the February on the fuse and see, and then possibly replace this fuse with the same one, but what value? Because the only thing I read was 1 on the housing. So 1k?
    If that doesn't help, I'll contact you privately.
  • #6 19685381
    DiZMar
    Help: 2894
    Rate: 6674
    gorylla wrote:
    I will replace this fuse with the same one, but what value? Because the only thing I read was 1 on the housing. So 1k?
    Fuses are specified in AND or mA . These 1 it 1A (1 Ampere).
  • #7 19685615
    gorylla
    Rate: 33
    Ooh, sorry, how could I not get it, it's Ampera. I'll go to the electronics store and buy it.
The discussion revolves around troubleshooting an LED lighting issue in an Amica FK200.4 refrigerator. The user discovered that the LED lamp was damaged and found a board with SMD diodes beneath the shade. Unable to find a replacement board in Poland and facing high shipping costs from England, the user opted to repair the LED. Initial checks on the F1 fuse legs showed no continuity, but after applying power, the LEDs illuminated, indicating a potential issue with other components. Responses from the community suggested replacing the F1 fuse, with clarification that it is rated at 1 Ampere. The user plans to first attempt to repair the fuse before considering replacement.
