Samsung No Frost Fridge - Display LEDs Blown: Repair Door Display & Accessing LEDs for Fixing
zielinskii 9669 4
  • #1 16707824
    zielinskii
    Help: 20
    Rate: 111
    Hello, I have a problem with the display on the fridge door. As in the subject, these are probably blown LEDs because they do not fully display the numbers. Is there any way to do this? How to get to it because there is no access from the inside.
    • Samsung No Frost Fridge - Display LEDs Blown: Repair Door Display & Accessing LEDs for Fixing IMG_20170919_130513.jpg (2.4 MB) You must be logged in to download this attachment.
  • #2 16707875
    El3ktr0d0wi3c
    Rate: 26
    If it's not the LEDs themselves, the entire display will be replaceable.
  • #3 16707879
    zielinskii
    Help: 20
    Rate: 111
    I found one but 200 zl for samsung rl40. Can't be repaired somehow? Easy to get to not him?
  • #4 16708006
    TYSSON
    Help: 5
    Hello. Disable the fridge from contact. Then, from the front of the fridge door, use a thin screwdriver to pry the display from below. It will slide out. The main clip is at the top of the display. Note the wiring harness. You can fix it if it's cold in February. Otherwise, just buy a new one.
  • #5 16708250
    zielinskii
    Help: 20
    Rate: 111
    Ok I'll see. The fridge works very well but it doesn't display exactly
