How to connect YTDY cables to Home Assistant via GPIO and MQTT panel: device selection
cantorre 1416 1
  • Requesting specific GPIO and MQTT hardware for YTDY wiring
    #1 19686481
    cantorre
    Hi
    I have 15 YTDY cables (3 pairs per cable i.e. 45 pairs) in a star system coming together at the control panel. Used to start will be 18 pairs (window contacts and control of 3 fans), the rest is for future development.
    Home Assistant is not yet standing, going one at a time. For information, it will stand either on the RPI 3+ or on the QNAP NAS HS-251+ (I happen to have both, hence the choice). In the future, there will definitely be some ZigBee-based sensors.
    I've already read that I should get some sort of GPIO panel, which I should connect to something that supports MQTT and further HA. Some people recommend that the MQTT server should also be a separate device, so I may go in that direction.
    And here's where I ask for help. How do I get these cables together and expose the interface for further work? I'm asking about specific devices to use. Price-wise I would like to fit in a few hundred zloty max. Any soldering is rather out of the question, but when it comes to some firmware changes or programming, I can handle it.
    EDIT
    I don't need (for what I'm asking) WiFi support. I have all my equipment in the control unit and it is wired as well as any cable connections.
    Thank you in advance for your answers
  • Recommend RS485 or CAN instead of long GPIO runs
    #2 19690626
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Well if you have an Rpi you don't want to solder then maybe something like this?
    https://botland.com.pl/raspberry-pi-hat-ekspa...Hnk3kLJ08U_Ufq9yT8fjR1RP8TfkViYBoC5p0QAvD_BwE
    By the way, using a centralised GPIO in one place and distributing it throughout the house I think is wrong.
    It's easy to get interference, surges etc on long runs connected via GPIO.
    If anything, I would rather use RS485 or CAN communication to connect to slaves, which already directly on short GPIOs handle sensors and actuators. Preferably with opto-isolation so that a short circuit or overvoltage at one point does not burn out the whole thing. Alternatively, use a wired LAN to communicate with remote devices.
