Peugeot 307 2.0 HDI 90km: Difficulty Starting, Replaced Glow Plugs, Battery, Injectors & More
majc55 7839 2
  • #1 16719094
    majc55
    I have a Peugeot 307 2.0 hdi, 90 km, I have a problem with starting. Yes, on a warm and on a cold engine.
    It takes a long time to shoot for it to fire.
    The glow plugs, battery, injectors, fuel pressure regulator were already replaced in the car, the starter was checked and it's ok, the compression was done on a cold engine.
    What else can I do in your opinion.
    I bet something with fuel, but I don't know for sure.
  • #2 16719281
    3piroman666
    Help: 25
    Rate: 57
    Hello, replace the fuel filter as it has not been replaced for a long time, and above all, go somewhere for diagnostics, see when starting how the fuel pressure increases on the rail, what is shown by the engine temperature sensor? were the injectors replaced with some used ones?
  • #3 18519499
    Marcin11136
    Hi buddy. And how did you deal with the firing problem?
    Added after 30 [seconds]:
