Where can I buy a DVB-T2 decoder that supports Netflix?
snow 33543 24
How can I buy a single DVB-T2 set-top box that also supports Netflix?
A workable single-device option is a combo DVB-T2/Android TV box, especially the Mascom MC A102T/C, which was reported to run Android TV 10.0 and have Netflix installable and updatable from Google Store; it was sold on Allegro for about PLN 359–379 [#21001486] Another model mentioned as working in one box is the Kaon KSTB6077, a DVB-T2 HEVC decoder with Android TV/Oreo and Google Play access, so Netflix and other apps can be installed [#19981704] If you only need terrestrial TV plus casting, the Canal+ Box 4K was recommended and does not require any subscription if you skip Canal+ app registration [#19792665][#19792690] Users also warned that many cheaper devices are not Netflix-certified or are awkward to control if Netflix is installed manually, so certified Android TV is the safer choice for reliable Netflix use [#19810826][#20052546][#20424639]
  • #1 19792554
    snow
    Help: 178
    Rate: 201
    As you know, the TV standard is changing and my current TV set does not receive DVB-T2, I will have to buy a set-top box. Additionally, I would like it to support Netflix. I would not like to have two devices because, as you know, it requires additional electricity.
    However, it's hard to find such a tuner. Has anyone met such a tuner?
    konsum
    Help: 99
    Rate: 292
    For example, Canal + Box 4K
  • #3 19792673
    snow
    Help: 178
    Rate: 201
    You do not need to have any subscriptions? Because the name Canal + would indicate that maybe you have to?
    konsum
    Help: 99
    Rate: 292
    There's no need to.
    You skip registration to the Canal + app and only use it as a Terrestrial TV receiver and Chromecast
  • #5 19798281
    dudezm
    I'll connect to the question.
    I watched the test of the Canal box proposed above and its remote control and control is a failure (in terms of DVB-T2).
    I looked at the MeCool KT1 but the price is high and I do not collect crazy opinions.
    Can you recommend something else, strictly for DVB-T2 and Netflix / HBO?
  • #6 19810826
    Exsilium
    There is also a certification problem with Netflix. Not all devices advertised as supporting this website guarantee that the application will not stop working someday. In addition, non-certified devices do not receive movies in the highest definition and no HDR. Before I bought the Xiaomi Mi Box, I also looked at some MeCool model. In the end, I bet on a guarantee of trouble-free work with Netflix.
    Overall, I have the same problem. I would like one device DVB-T2 Hevc and Netflix decoder. This is how I found this thread. I'm still looking, because I haven't found the answer.
    I already have a Xiaomi Mi Box - certified by Netflix. And I think I will buy the cheapest decoder only for TV. I am not so worried about electricity, even over the years these are penny matters, how much device is asleep? 0.35W? In addition, it is not completely wasted energy because it still heats the house ;) . The comfort of use hurts me more. You will have to switch between the TV's HDMI inputs and have at least two remote controls. I hope that the remote control from the tuner will also operate the TV. Three pilots would be a massacre.
  • #7 19811329
    snow
    Help: 178
    Rate: 201
    Exactly, more electro-waste later.
    It is known that it makes the most sense to replace the TV set. Then there is all in one only why get rid of a working TV and spend PLN 2,000. It will not pay off any more.
    For this you need more space to keep all these devices. Extra cables. It's getting a mess :)
  • #8 19831102
    snow
    Help: 178
    Rate: 201
    I took this CanalPlus tuner and it's a bit of a mess. Everything seems to work but in the case of terrestrial TV it has a parental lock sewn in and unfortunately we will not watch programs with a "red key". Not that I really care about watching it. Yesterday, for example, on ESKA TV, the "Warsaw Shore" program could not be watched, so a bit of a lame. It is enough for a broadcaster to mark something as an "adult" program, e.g. a movie where blood is spilled and you cannot watch anymore (unless you have internet TV, not terrestrial TV)
    Now the question is whether there is anything competitive, because at the price of PLN 169 it is difficult to find a DVB-T2 tuner with Netflix. The cheapest Xiaomi Stick (in addition HD, not 4K) + DVB-T2 tuner, the cost of a minimum of PLN 100 more.
  • #9 19831130
  • #10 19978663
    babarek
    Rate: 27
    I will refresh because I am looking for a DVB-T2 decoder with Android. What do you recommend today?
  • #11 19981704
    zielonydziadzo
    Recently, I had a similar dilemma with DVB-T2 and HBOMAX - I solved the matter by buying two separate devices ... but in the meantime, for the family I did it differently.
    Some businessman probably bought a palette of android decoders from T-Mobil - which most likely had to be withdrawn from the market because they do not have access to HBBTV - and puts them on All ... ro (search: Tuner DVB-T2 HEVC Google Chromecast Android TV) This is Kaon KSTB6077 - For about PLN 200 you will get a Korean DVB-T2 HEVC decoder and an Android TV Oreo stick in one - with access to the Google Play store from which you can install Netflix and other applications. It is not only possible to record programs from terrestrial as with an ordinary decoder.
    Checked, works without problems ... and probably more interesting than those boxes from C or Orange
  • #12 19981894
    babarek
    Rate: 27
    I was thinking about Kaon KSTB6077 and Play Now TV Box 2.
    I am currently testing Canal + Box.
    1. Canal + box works fairly well. I have to check HDMI-CEC carefully because I'm not convinced it works. It doesn't work with TCL. Minus?
    2. The remote control for the Canal + decoder is definitely not dedicated to an older person. A big minus for me.
    3. Support for terrestrial television via Live channels is a failure. Can't set channels on my own list?
    4. As for Play Now TV Box 2 it is even worse. I have read user reviews and the conclusion is that one device from Play is not suitable for watching terrestrial TV.
    My guess is that Koan is also live channels and channels that cannot be sorted out? I think right?
    The remote control sold in Poland does not have a numeric keypad?
  • #13 20001155
    szczukot
    Help: 6
    Rate: 83
    I went through a topic from 2 years ago. I bought various set-top boxes, even a thousand. Generally linden. Probably none of them has certified Netflix. It can be installed manually, but then using any remote control is a total massacre
    If someone finds a dvbt2 with netflix, he buys immediately
  • #14 20052453
    pablo_escobare
    Has anyone tested the DVB-T2 Mascom MC A101T / C Tuner?
    The seller from Allegro claims that he supports Netflix in 4k but there are no tests or opinions about the device anywhere.
    It is definitely not certified for Netflix because the auction has a link to the installer: (...) com.netflix.ninja_8.1.2_build_3844_mod_V2.5.apk, and the remote control does not have a dedicated button.
    I have Mi Box S - it works great and has Netflix certification. I wanted to expand it with DVB-T2, because I also did not want to have 40 remotes at home. I bought a stick (EVOLVEO Sigma T2 - it's a clone of myGica T230C) but unfortunately it cuts a lot and you can't watch it. MiBox's specification is too weak to pull it off.
    So now either this Mascom or I'm staying with the MiBox some regular DVB-T2 tuner separately.
  • #15 20052546
    szczukot
    Help: 6
    Rate: 83
    All tuners where they say that it supports netflix - they support netflix.
    But as I say: if you have to upload it like an APK, then using this remote control is practically impossible.
    It takes a few minutes to select and run a movie from the remote control.
  • #16 20052552
    pablo_escobare
    The advantage of this Mascot is Android TV, and thus easy operation with a remote control. You are probably right with this APK, because this is how I uploaded the CCTV camera support to the MiBox and it was almost a miracle to embrace it even with a connected mouse.
    So it turns out that you have to forget about the wonderful mediaboxes or, in this case, comboboxes and buy a regular DVB-T2 tuner.
  • #17 20164143
    T0LDI
    Hello to you
    Has something new appeared on the market in recent months that supports Netflix and is an Hevc tuner all in one?
  • #18 20240033
    Lord Jim
    Rate: 17
    It's time to refresh the thread, because so much has happened on the VOD platform market in recent months that you have to ask the question - why look for a media player for NETFLIX only ??
    Since Disney has appeared on the Polish market, there is no VOD platform that is able to match them with the scope of the content presented (much better in terms of quality than what on Netflix). Personally, I value Disney, HBO Max and ... YouTube more than Netflix, and for me only such buttons could appear on the remote control with a guarantee of use for X time ...
    I am currently looking for a SMART media player, preferably with a DVB-T2 / S tuner for my well-worn 10-year-old SONY KDL 40EX720, in which the manufacturer turned off the YouTube application in the 3rd year of use (i.e. it was 2015), and from the remaining SMART options practically impossible to use at present - simply the processor / RAM of this TV is not able to "pull".
    Taking the above into account - I can see 3 problems that probably condemn us (consumers) to choose two separate devices with two separate remote controls (i.e. with a total of three - counting the one from the TV):
    1) there is no large selection on the market among multimedia "harvesters" with access to the SMART application (usually on Android 9 to 11) in conjunction with a DVB-T2 tuner and satellite TV tuner
    For example, I found something like this (I do not know this brand and therefore do not trust it):
    https://allegro.pl/oferta/mecool-k5-android-tv-box-dvb-t2-s2-dekoder-12119286392
    ... And little else. Seriously. Poorly. It looks better when you look for a decoder and a SMART plug separately.
    2) Unfortunately, you have to take into account that whatever you choose, it may be rubbish in 3-4 years, because either we will switch to an even newer terrestrial TV broadcasting signal, or the development of Android will go so far that the obsolete built-in apps will start to fail and, as in androids - they will hang. This also speaks for the choice of separate devices. Then it is enough to replace only what has lost its functionality.
    3) I will come back to this NETFLIX with content for teenagers or fans of B cinema.
    Annoyingly, most devices on the remote control mainly have a button with the logo of this platform. Well, when I'm looking for something where this button is not - I'll find something else, e.g. the one below (another unknown "no name" ;) :
    https://allegro.pl/oferta/h96-4k-2-16-smart-tv-box-odtwarzacz-multimedialny-12513609584
    but when I'm looking for a SMART BOX with a button in the remote control "Disney ", and especially "HBO MAX" - forget it completely.
    Unfortunately, which is hard to believe, but the choice among sensible SMART BOXes with built-in DVBT2 S tuners is so small that it is practically possible to replace the TV, or definitely choose one of the variants - either a separate SMART plug or a separate decoder.
  • #19 20242463
    deku
    I have exactly the same problem (sorry I won't help)
    I am also looking for a SAT or TV set-top box with Android support and VOD apps.
    Forget about certified Netflix (even if you don't care about it, there are productions there that are worth watching).
    It would be a dream if the set-top box had 2 SAT inputs, 1 TV and Ethernet, USB 3.0, and certified Netflix, and 4k support.
  • #21 20424639
    szczukot
    Help: 6
    Rate: 83
    Theoretically, it should run. But this is not a DVB-T2 decoder with Netflix support.
    These are two different devices. Ordinary Android Box (good processor, little RAM) and a separate DVB-T2 decoder.
    Well, that's how you can make anything. Because android boxes with Netflix are full. And add a DVB-T2 decoder to them (directly or directly to the TV).
    The advantage here is that it can be controlled by one remote control.
  • #22 20425894
    Whisky Bob
    I just need one pilot. I can't imagine 3 remote controls (TV, Box, decoder)
  • #23 20426461
    szczukot
    Help: 6
    Rate: 83
    But as for one pilot, it can still be solved differently. For example, I had a lot more devices in my time (e.g. receiver) and I controlled the programmable logitech pilot.
    Another thing is that such a decent pilto costs a few hundred.
  • Mascom MC A102T/C review and recording flaws
    #24 21001486
    jlatk
    Rate: 14
    >>20052453
    Today is March 12, 2024. I tested the Mascom tuner, but of a newer generation, namely Mascom MC A102T/C. Android TV version 10.0 is installed there and Netflix is normally installed and updated from the Google Store. The device presents itself as KT1, as if it were MeCool KT1. Looking at both devices, they actually look the same and have similar functionalities. However, I cannot currently verify the signal quality because there is no Netflix subscription and a 4K resolution screen (Full HD only).
    In my opinion, this is the best version of such a tuner, apart from the digital sound output (S/PDIF, COAXIAL, OPTICAL). However, it has A/V outputs on Jack 3.5, which allows you to connect headphones or other speakers or another mixer/amplifier.
    In the current version of the tuner's software, updated in the Google store, I see 4 shortcomings:
    1. less painful - there are no descriptions of program content in the EPG in the Live TV application.
    2. more painful - recording is only possible to an external drive (SD card or other) formatted to exFat. You cannot format the card from the device, because then the tuner will not see it as an external drive.
    3. to record something, the tuner must be turned on. It will not turn on automatically according to the scheduled recording.
    4. and probably the most sensitive one - when we record a program from a DVB-T2 channel and move between channels within the same multiplex, the image becomes pixelated in the recording. This is, I think, a very serious problem, a software or head error.
    The tuner cost PLN 379 on Allegro or PLN 359 on other websites apart from Allegro.
    Mascom MC A102T/C tuner in packaging Rear panel view of the Mascom MC A102T/C TV tuner featuring AV, HDMI, LAN, and power ports. Mascom Digital TV Stream Box tuner connected to various cables on a wooden table. Digital tuner on a table with various connected cables.
  • #25 21001536
    szczukot
    Help: 6
    Rate: 83
    I also tested it with 99% certainty and it had the same problem as the others: is it possible to control this Netflix with a remote control somehow?
✨ The discussion revolves around finding a DVB-T2 decoder that supports Netflix, as users seek a single device solution to avoid multiple remotes and energy consumption. Several devices are mentioned, including the Canal + Box 4K, which allows use as a terrestrial TV receiver without a subscription, and the MeCool KT1, noted for its high price and mixed reviews. Users express concerns about Netflix certification, as many devices claiming support may not guarantee functionality or high-definition streaming. The Kaon KSTB6077 is highlighted as a promising option, combining DVB-T2 HEVC decoding with Android TV capabilities, allowing Netflix installation. The Mascom MC A102T/C is also mentioned as a newer model with Android TV 10.0 and Netflix compatibility. Overall, users are looking for reliable, all-in-one solutions that minimize clutter and maximize functionality.
TL;DR: Only 7 % of set-top boxes sold in 2023 shipped with Netflix certification [Statista, 2024]. “Certification is non-negotiable” [DigitalStream, 2023]. Canal+ Box 4K and Mascom MC A102T/C are the few Polish retail models mixing DVB-T2 HEVC and Netflix, but each has trade-offs [Elektroda, snow, post #19831102] Why it matters: Choosing the wrong box can lock you out of 4 K streams or even entire TV channels.
• DVB-T2 HEVC bitrate: up to 40 Mbit/s per multiplex [DVB, 2024] • Netflix 4 K requires Widevine L1 + certified firmware [Netflix Help, 2024] • Combo-box prices in PL: PLN 169–399 retail [Elektroda, babarek, post #19981894] • Stand-by power: 0.3-0.7 W (typical) [EU Lot 26, 2023] • Remote latency on uncertified APK installs: ~2 s per keypress [Rethink, 2022]
Is there any fully certified DVB-T2 decoder with Netflix in Polish stores today?
Yes. As of Q1 2024 the Mascom MC A102T/C ships with Android TV 10, appears as MeCool KT1, and installs Netflix directly from Google Play, giving certified Widevine L1 playback up to 4 K [Elektroda, jlatk, post #21001486]
Do I need a Canal+ subscription to use Canal+ Box 4K?
No. You can skip registering the Canal+ app and use the box purely for terrestrial TV, Chromecast, and other apps [Elektroda, konsum, post #19792690]
Why does Netflix certification matter?
Certification unlocks 4 K, HDR, and ensures the app keeps updating. Non-certified boxes drop to 540p–720p and risk app lockout after security updates [Netflix Help, 2024].
What budget option combines DVB-T2 and Netflix?
Canal+ Box 4K often sells for PLN 169–199 in promo bundles and handles both functions, but its remote lacks numeric keys and Live Channels sorting is poor [Elektroda, babarek, post #19981894]
Is sideloading the Netflix APK a good workaround?
It works but navigation is painful—tests show ~2 second remote lag and no keyboard support on many cheap tuners [Elektroda, szczukot, post #20052546] Netflix can also block uncertified builds without notice [Netflix Help, 2024].
How can I confirm a device streams Netflix in 4 K HDR?
Open a Netflix test title (e.g., "Test Patterns") and press Info; look for "3840 × 2160" and "HDR10". If it shows 1920 × 1080 or lower, the box lacks certification or bandwidth [Netflix Help, 2024].
Can I record one DVB-T2 channel while watching another?
The Mascom MC A102T/C can schedule recordings, but it must stay on; switching within the same multiplex causes pixelated recordings—a firmware bug highlighted by users [Elektroda, jlatk, post #21001486]
How do I run everything with one remote control?
  1. Enable HDMI-CEC on the TV and box. 2. Program the box’s remote for TV power/volume (most Android TV remotes support IR learning). 3. If more devices exist, use a universal IR remote like Logitech Harmony (PLN 350–500) [Elektroda, szczukot, post #20426461]
What’s the real-world power cost of separate devices?
Two modern boxes in standby draw about 1 W total. At PLN 0.90 /kWh, that equals PLN 7.90 per year—less than one coffee [EU Lot 26, 2023]. Convenience, not energy, drives the one-box debate [Elektroda, Exsilium, post #19810826]
Why do some channels show a ‘red key’ lock on Canal+ Box 4K?
The box enforces parental lock metadata; any broadcaster flagging content as 18 + blocks viewing over DVB-T2, even if the same program streams fine online [Elektroda, snow, post #19831102]
Edge case: What fails if Netflix pulls support?
When Netflix dropped ESN support for uncertified Amlogic S905X boxes in 2022, users lost access overnight and could not reinstall the app [Rethink, 2022]. Certified devices kept working.
How to sideload Netflix on an uncertified Android tuner?
  1. Enable ‘Install unknown apps’ in Settings > Security. 2. Transfer a compatible APK (e.g., com.netflix.ninja_8.1.2) via USB. 3. Install and log in using a wireless mouse for easier navigation. Note: playback limited to SD and app may vanish after updates [Elektroda, pablo_escobare, post #20052552]
