Which DVB-T2 / HEVC decoder to choose and can I connect it to the antenna withou
ZbyszekKieliszek 18960 3
  • Clarifying antenna compatibility and budget decoder options
    #1 19913778
    ZbyszekKieliszek
    I have an old TV set and due to the imminent introduction of the new DVB-T2 / HEVC standard, I will have to buy a set-top box. I have two questions:
    1. The TV set is connected only to an ordinary room antenna, will there be no problem with connecting the DVB-T2 / HEVC decoder to such an antenna?
    2. Can you recommend any specific, inexpensive DVB-T2 / HEVC set-top boxes in the range of PLN 100 - 120?
  • Antenna compatibility is not decoder-specific
    #2 19913819
    _kli_
    Help: 760
    Rate: 1038
    ad.1. There will be no problem. For the dvb-t2 decoder it doesn't matter what antenna you connect to it. It is important that she receives the signal well
    ad.2. There are many such set-top boxes on the market. You can often get the impression that it is the same decoder with different names and in a slightly different housing. There is a channel on YT with a lot of tests of currently available set-top boxes. Most often, their price is around PLN 100. Maybe you can choose something for yourself - https://www.youtube.com/c/TabletradarSmartTest/videos
  • #3 19914365
    LeDy
    Help: 1990
    Rate: 2937
    I recommend Wiwa H.265 Lite. I had it and it worked fine.
  • #4 19926112
    jacekko63
    Help: 140
    Rate: 320
    I recommend the LTC tuner, good head sensitivity.
