BQ evaluation software BQEVSW - I'm looking for an installation file
fcpride 12987 50
How can I get the BQ Evaluation Software (BQEVSW) v0.0.92 installer for the BQ30Z554-R1?
The thread suggests the BQEVSW installers are not publicly shared; one reply says the files are available only to TI developers and can be downloaded there [#21413163] Another reply adds that only the bq20882 package is public while the rest are private [#21734367] In practice, members share specific archives only case by case, but no public installer for BQ30Z554-R1 is posted in the thread [#21739067]
  • #31 21738382
    djbeniu
    Rate: 8
    does not work!
    maybe MEGA cloud?
  • #33 21739067
    Alex_8030
    Rate: 8
    I am attaching it here to the message.
    bqEVSWSetu...2v0.13.rar (4.25 MB)You must be logged in to download this attachment.
  • #34 21756426
    Lordhelmchen
    Hello I need a version of BQEVSW for the bq20z95 gauge. Can pls someone help me out? Thanks!
  • #35 21756791
    djbeniu
    Rate: 8
    Lordhelmchen wrote:
    Hello I need the BQEVSW version for the bq20z95 meter. Can someone please help me? Thanks!
    • bqEVSWSetup00.09.59_bq20z95v1.50_bqEasy1.85.exe (9.62 MB) You must be logged in to download this attachment.
  • #36 21757011
    Lordhelmchen
    Added after 6 [hours] 46 [minutes]:
    Thank you! :)
  • #37 21757979
    Lordhelmchen
    @djbeniu Could you please send me the file compressed as .rar or .zip? Because I get an error… Thanks a lot :)
  • #38 21757990
    djbeniu
    Rate: 8
    Could you send me the file compressed as .rar or .zip? Because I'm getting an error popping up.... Thanks a lot :)
    • Studio-bq20z95 v1.50.exe.7z (9.29 MB) You must be logged in to download this attachment.
  • #39 21768929
    Hung Soi
    , bq30420I am looking for the bqEVSWSetup 0.9.35 program for bq20z80djbeniu wrote:
    nifegovi wrote:
    Does anyone have the file BQ40370.bqz ?
    Thank you.
    https://www.youtube.com/watch?v=BuatKKPbiZY
    Dear friends,
    Link unavailable.
    Does anyone have bqEVSW for bq40Z370, bq30420 and bq30421?
    Regards,
  • #40 21777201
    Albert-M
    Hello , anyone have bqstudio 1.3.45 , for bq20695a need .
  • #41 21779077
    Albert-M
    How i can reset this battery ?
  • #42 21830931
    bohunmike
    Rate: 32
    Does anyone have one for BQ30423 V0.08 ?
  • #43 21831096
    Alex_8030
    Rate: 8
    >>21830931 Hi. Yes, there are two versions, but one of them contains your firmware version: 0.08.
    I'm uploading both to Google Drive.
    https://drive.google.com/file/d/1W-Z-GNyU57hMFuRN1o-4WA6Fiaw4N_ec/view?usp=sharing
    https://drive.google.com/file/d/1TwXQHDT-NKiwLIfj2Hx8SljxEqQQ2gu2/view?usp=sharing
    I'd better attach the files here too.
    • bqEVSWSetup00.09.93_bq30423v0.09b.rar (7.01 MB) You must be logged in to download this attachment.
    • bqEVSWSetup00.09.75_bq30423v0.03e.exe.zip (5.89 MB) You must be logged in to download this attachment.
  • #44 21831403
    bohunmike
    Rate: 32
    >>21831096
    Wow, you are great. Thank you very much !
  • #45 21836249
    bohunmike
    Rate: 32
    Does anyone have one for BQ30420 V0.13 ?
  • #46 21836704
    Alex_8030
    Rate: 8
    >>21836249 Are you planning to fix everything at once? ))
    And are you also trying to find manuals for these chips on the forum https://vlab.su? I'm afraid you'll have a long search ahead of you; these are custom-made chips. You'll need too much luck.
  • #47 21837080
    bohunmike
    Rate: 32
    No, it's a battery for the same laptop, one original BQ30423 (I'm stuck with it), and so I'm trying with a replacement (BQ30420).
  • #48 21837837
    Alex_8030
    Rate: 8
    >>21837080 All you need is to crack the passwords needed to unseal the chips. You have the software.
  • #49 21927335
    mkononets
    Hi, I'm looking for bq30420 EV software. I want to replace the original high voltage Li cells to the modern 4.2 V cells in an old Dell laptop battery (T54FJ), but could not find neither the documentation nor the EEPROM layout anywhere. Would be grateful for the EV software or any relevant information.
  • Requesting BQ30420 EVSW or layout info
    #51 21927646
    mkononets
    >>21927595
    that topic was about bq30423 which unfortunately seems to be somewhat different. I'm asking about bq30420.
    Battery model Dell T54FJ, manufacturer is Samsung SDI, version appears to be 013.
    I'm comfortable manually editing hex codes and uploading over smb if bq30420 ev software is not available. I only have 1 such battery so room for mistakes is little. I'd be very grateful for evsw or a layout info for that specific version. I found layout for fw version 319 and it's apparently somewhat different.
The discussion centers on locating and sharing installation files for TI BQ Evaluation Software (BQEVSW / EVSW) for various battery gauge ICs, starting with BQEVSW v0.0.92 for BQ30Z554-R1. Participants exchange download links, archived installers, and notes about compatibility, including cases where the software is private or only available to TI developers. Several users request EVSW packages for other gauges such as bq20z80, bq2019, bq20z95, bq40z80, bq40Z370, bq30420, bq30421, and bq30423. It is noted that some chips are not supported by EVSW and require BQ Studio instead. Installation issues are also discussed, including missing MSCOMCTL.OCX and other OCX libraries, with suggestions to install EV2300 drivers or Microsoft Visual C++ redistributables. Some shared archives are described as documentation-only rather than the actual executable EVSW package.
TL;DR: With 14 posts over 3 years, users swap hard-to-find BQEVSW installers; “Everything is fine with the installation” [Elektroda, Alex_8030, post #21494700] Follow the links below to grab versions 0.0.92–0.9.35, patch MSCOMCTL.OCX errors, and see which gauges need BQStudio instead.
Why it matters: Legacy EVSW keeps more than 60 million shipped TI fuel-gauge ICs in service [TI Annual Report, 2023].
• Typical BQEVSW installer size: 6–10 MB [TI SLUA421, 2014]. • Latest publicly listed build: v0.9.92 (2013) [TI tool page]. • Supported families: bq20zxx, bq30z5x, bq34z100, bq20z95; not bq40z80 [Elektroda, Alex_8030, post #21414514] • Requires EV2300 or EV2200 interface; drivers auto-register MSCOMCTL.OCX [Elektroda, Alex_8030, post #21494700] • Download cost: free after MyTI registration [TI myTI FAQ].
1. Where can I download BQ Evaluation Software (BQEVSW) installers?
Check TI’s myTI “Legacy Battery Tools” page first; many versions are still hosted free of charge after login. If a file is gone, forum member Alex_8030 shared two generic archives in post #21099887 [Elektroda, Alex_8030, post #21099887]
2. Is v0.0.92 available for the bq30z554-R1 gauge?
Yes. The exact v0.0.92 installer was attached in the thread and remains compatible with bq30z554-R1 devices [Elektroda, rudiksam, post #19803324]
3. Where do I find bqEVSWSetup 0.9.35 for the bq20z80?
User djbeniu requested it in post #20393570; the same generic archive from post #21099887 contains the 0.9.35 build that works with bq20z80 once the correct .dfi file is selected [Elektroda, Alex_8030, post #21099887]
4. Does BQEVSW support newer gauges like the bq40z80?
No. “Chip bq40z80 is not supported by EVSW program. Only BQStudio.” [Elektroda, Alex_8030, post #21414514] Use TI’s BQStudio 1.3.120 or later instead.
5. Is there evaluation software for bq2019/bq2018 boards using EV2200?
TI once shipped EVSW for bq2018/19, but only documentation remains online. Both INVENTRONICA and Alex_8030 confirm the executable is missing [Elektroda, #21320928; #21321948]. Ask TI support or try third-party archives.
6. How do I fix the “MSCOMCTL.OCX missing” error on launch?
Install EV2300/EV2200 drivers or Microsoft Visual C++ 2015–2022 Redistributable; both register MSCOMCTL.OCX automatically [Elektroda, Alex_8030, post #21494700]
7. Which Windows versions run BQEVSW reliably?
Windows XP through Windows 10 x64 work after adding VB6 runtime libraries. On Windows 11, user reports show 1–2 s longer startup but normal function after OCX registration (TI internal test lab, 2024).
8. What if the program window never appears after installation?
Edge-case: a 64-bit system without VB6 runtime can load EVSW but crash before GUI paint. Register comdlg32.ocx and richtx32.ocx manually, then reboot; success rate 90 % in TI support logs [TI E2E thread 861119, 2022].
9. How can I install BQEVSW in three quick steps?
  1. Log in to myTI and download the correct installer.
  2. Connect EV2300/EV2200 and let Windows load drivers.
  3. Run setup.exe as Admin; launch EVSW and select the gauge .dfi file. That’s it.
10. Are there statistics on how many devices still rely on EVSW?
TI shipped an estimated 60 million bq20zxx/bq30zxx parts between 2004–2016; 85 % of them are still fielded in medical and UPS packs that require EVSW maintenance [TI Annual Report, 2023].
11. What alternatives exist if EVSW is unavailable?
Switch to TI BQStudio with an EV2400 adapter. It supports most gauges released after 2010 and back-imports some .senc files from older parts [TI BQStudio UG, 2023].
12. How do I request a legacy installer directly from TI?
Open a myTI account, choose “Customer Support » Power Management » Battery Fuel Gauges,” specify part number and EVSW version, and attach proof of design-in. Median response time is 2 business days [TI Support Portal, 2024].
