IMMERGAS Vitrix Exa Boiler: Smart Home Integration & Aqua Celeris Water Heating Tips
kutyatatika 1866 2
  • Seeking direct control of aqua celeris heating
    #1 19852855
    kutyatatika
    Hello! I have installed an Immergas Vitrix Exa boiler. Heating is operated in a "smart home" environment through Node-red. The toggle of the heating is solved, but I would like to switch on the prompt water heating service "aqua celeris" or set a sanitary period for starting make water heating as the CAR_V2 refers to/offers. Do you have any tips & tricks how can I reach this function directly on the electric board, without installing CAR_V2 like devices. I would like to integrate these functions to my smart home environment. Any DIY pcb / microelectronic solution might be interesting, too.
  • #2 19857426
    Przemko21
    Help: 110
    Rate: 307
    How u connected Victrix Exa to smart home system. Do u use opentherm protokol ?
  • #3 19860070
    kutyatatika
    Przemko21 wrote:
    How u connected Victrix Exa to smart home system. Do u use opentherm protocol ?
    I use Home assistant and Node-red to control the temperature. Unfortunately only the thermostat I/O is easily accessible.
