Accessing Settings/Menu on Immergas Victrix Zeus 26 Boiler: Procedure & Code Retrieval
Fafunio13 12588 9
How do I enter the settings/service menu on an Immergas Victrix Zeus 26 boiler and obtain the access code?
You cannot enter the service menu without the correct service code; if the code is wrong, the “ID” display disappears as soon as you release the knob [#16299695] The thread does not provide a valid access code for the Victrix Zeus 26, and a later code that was posted was explicitly marked as not applicable to this boiler model [#21389021] One reply also states that this model does not have an “ID” item in the service menu for correcting the outside temperature sensor [#21389365] If you are trying to change boiler power, the forum warns that this must be done with a micromanometer and not by guessing, because incorrect settings can damage the boiler [#16303248][#16304916]
  • #1 16297292
    Fafunio13
    I need help, how to enter the settings / menu of the Immergas Victrix Zeus 26 boiler?
    In the user manual book, they say to get an access code, just how?
    Then turn the knob to RESET and hold for 15 seconds, after which ID will appear. When I release the knob, the ID disappears and the stove returns to normal operation.
  • #2 16299695
    Rysio4001
    Heating systems specialist
    Help: 617
    Rate: 1077
    You have not set the correct service code, therefore the ID symbol disappears.
    And for what purpose do you want to rummage in the service menu, and what do you want to change there?
    By changing the parameters, without knowing what they are responsible for, you can lead to incorrect operation of the boiler, its damage or destruction, and you can even lead to a dangerous event.
    Greetings.
  • #3 16301436
    Fafunio13
    I would like to reduce the power of the stove, because I pay the gas bills 600-700 PLN monthly. A friend pays 250-300 PLN for a similar house. So why not give it a try? The furnace has a power of 3 kW to 26 kW, perhaps it is set to 20 kW.
  • #4 16303248
    mauri_b
    Help: 109
    Rate: 529
    You must have a micromanometer for this. It is impossible with the eye.
  • #5 16304916
    Rysio4001
    Help: 617
    Rate: 1077
    As a colleague wrote above, without a micromanometer you will not be able to determine what power you are setting, and in case of exceeding the permissible maximum power, or setting below the minimum permissible, you can seriously damage the boiler!
    Moreover, changing the set boiler power will not cause drastic changes in gas bills.
    Your statement shows that two similar objects, and in one of them gas consumption, is more than twice as high. Power regulation will certainly not cause such changes in the case of this boiler model.
    The reasons for such differences must be sought elsewhere.
    The fact that the boiler has a higher power setting does not mean that it will work with such power. After firing up the burner, the boiler starts working on CO with minimum power and only slowly increases its power over time. If the set temperature is reached, it stops increasing the power, and if the temperature exceeds it, it starts to reduce the power again until it stabilizes at a level that maintains the set temperature.
    If you reduce the boiler power below this power, the boiler will not be able to reach the set temperature.
    Similarly, by lowering the set temperature, you will make the boiler work with lower power.
    It can go to higher power for some time, it will not reach the set temperature by the knock.
    I am talking about the water temperature in the central heating system
    So, as already mentioned, the reasons for such drastic differences in gas consumption must be looked for elsewhere.
    Greetings.
  • #6 16304959
    Fafunio13
    So what should be the optimal water temperature for underfloor heating throughout the house?
    Do different boiler manufacturers have an influence on such a difference in combustion?
  • #7 16305031
    Rysio4001
    Help: 617
    Rate: 1077
    Such that the heating works almost constantly and does not clock (I warm up the house quickly, turn it off and wait for the temperature to drop a bit, and again and again and again and again). Then it is the most economical.
    I will not give a specific temperature, because the most appropriate one is different for different buildings. You have to find it yourself, achieving the effect described above.
    No. Condensing boilers, regardless of their manufacturers, have similar efficiencies.
    There are also condensing boilers, which are in fact turbo boilers with a condensing attachment (the so-called recuperator). These have lower efficiency.
    Your boiler is not one of them.
    How do you have a regulated temperature on the floor heating. It goes directly from the boiler, is there any mixing system, etc.
    Is this gas consumption from the beginning or for some time.
    When was the boiler last cleaned and adjusted, maybe that's where the problem lies.
    And one more thing:
    Fafunio13 wrote:
    ... because I pay the gas bills 600-700 PLN monthly. A friend pays 250-300 PLN for a similar house.
    Similar does not mean the same. Moreover, the size itself is not all. You also have to compare the thermal insulation method, building thermals, DHW consumption, etc.
    For example: a very well insulated building can use much less fuel for CO needs than a poorly insulated building with a much smaller area.
    Another thing is DHW. Heating a DHW consumes a huge amount of energy. Large differences in DHW consumption can generate large differences in gas consumption, even such.
    Greetings.
  • #8 19528697
    frogpl
    Rate: 21
    Can anyone suggest how to enter the service menu ..., I need to make a correction on the external temperature probe, it is distorted by 4 degrees. Greetings. Victrix Zeus 26 1.
  • #9 21389021
    warszawasailing
    As I had a big problem finding the pin code for the service menu, I am giving it for posterity. The pin code is xxx
    Moderated By gulson:
    This is not the code for the boiler model in question.
  • No outside temperature correction in service menu
    #10 21389365
    Rysio4001
    Help: 617
    Rate: 1077
    frogpl wrote:
    Can someone suggest how to enter the service menu .... , I need to make a correction on the outside temperature probe, it is overcorrecting by 4 degrees. Greetings. Victrix Zeus 26 1 .
    On this boiler model, there is no "id" in the service menu for the correction of the outside temperature sensor.
    warszawasailing wrote:
    Because I had a lot of trouble finding the pin code for the service menu, I am providing it for posterity. The pin code is ...
Accessing the service menu on the Immergas Victrix Zeus 26 boiler requires entering a correct service code; otherwise, the ID symbol disappears shortly after attempting access. The procedure involves turning the knob to RESET and holding it for 15 seconds until the ID appears, but releasing the knob without the correct code causes the boiler to revert to normal operation. Adjusting boiler power settings without proper tools, such as a micromanometer, and knowledge can damage the boiler or cause unsafe conditions. Power regulation alone is unlikely to significantly reduce gas consumption, as the boiler modulates power based on temperature demand. Optimal water temperature for underfloor heating should maintain near-constant operation to avoid frequent cycling, but exact values depend on building characteristics. Differences in gas consumption between similar houses are more likely due to factors other than boiler power settings or manufacturer efficiency, as condensing boilers generally have similar performance. For correcting external temperature probe offsets, the Victrix Zeus 26 does not provide an "ID" code in the service menu, and the previously suggested pin codes may not apply to this model.
