Krups EA89 - Poor coffee from the machine does anyone know the code?
szabgab 6477 6
  • #1 19861138
    szabgab
    Dear everyone, thank you first of all for allowing me to join. Sorry for my poor language, I use Google Translate because I'm Hungarian. In any case, I have a Krups EA89 machine that does not make strong coffee, grinding time 7-8 seconds. Does anyone know how to enter the service menu? Thank you!!!!
  • #2 19865680
    roman_partyka
    Help: 68
    Rate: 295
    What do you mean by "weak coffee"?
  • Request to increase grind time and tamping strength
    #3 19867824
    szabgab
    Dear Roman, thank you for your reply. Sorry, I just wanted to keep it simple in case Google translates something badly :) Anyway, what I meant was, the machine produces watery coffee, not very strong in general (neither in taste nor in effect). I have tried all the various available settings - grind size, dark coffee, water temperature, but none of those produce a satisfying outcome. We use a Delonghi Icona in general, which is a LOT cheaper machine and from that the coffee (from factory pre-ground coffee) is creamy, has got some nice 'thickness' to it and is stronger too. As the Krups was a present from my father, I would like to keep it, hence the reason I am looking for a solution to this problem. If I could lengthen the grind time (currently 8 seconds for dark coffee) and/or the tamping strength, that should give me some extra options to try.
    Thanks!
    Gabriel
  • #4 19872759
    roman_partyka
    Help: 68
    Rate: 295
    Is the coffee puck compact or is it a clump?
  • #5 19876964
    szabgab
    It is somewhere in between, compact with broken edges; if you take it out of the holder, it falls apart very easily.
  • #6 19881932
    roman_partyka
    Help: 68
    Rate: 295
    It's rather good.
    The amount of coffee in the cup is appropriate?
  • #7 19897358
    Daimond140
    there is no code for it,
    You have made more than 8000 cups.
    Replace the pressure head (15€) completely not only the o-rings (4€), this pressure head also contains a rubber inside the frame work
    (not for sale separately).
    this also provides foam and of course taste.
    Once replaced you see difference
The discussion revolves around a Krups EA89 coffee machine that produces weak, watery coffee despite various adjustments to grind size, water temperature, and coffee strength settings. The user, Gabriel, compares the output to a Delonghi Icona, which yields a creamier and stronger brew. Responses from other users inquire about the coffee puck's consistency and suggest that the issue may be related to the machine's pressure head, recommending its replacement to improve coffee quality and foam production.
