Krups EA 8050: Coffee Leakage Inside Machine & Bubbling During Brew Process
Zabek-TimmY 20124 14
Why does a Krups EA8050 leak coffee inside the machine and bubble around the brewing piston during brewing instead of sending all the coffee into the cup?
The leak is most likely caused by worn seals in the double-tap valve / brewing piston assembly, and replacing the O-rings on the double-tap valve piston and the valve itself fixed the problem in one case [#16423731][#16810244] Check the machine with the side cover removed so you can see exactly where the water escapes [#16780092] If you service it yourself, replace the seals comprehensively, clean the brewer and grinder, and use grease that is resistant to water and temperature; ordinary silicone is not recommended for long-term sealing [#16425272]
  • #1 16422907
    Zabek-TimmY
    I had a problem with the express machine. I turn on the coffee machine, choose coffee and the grinder switches on, they had coffee and it starts brewing coffee. Only some of the coffee is poured into the cup and some are leaking somewhere in the coffee machine. Another symptom of the same is that, including cleaning, it all flies into the drip tank and only during rinsing water pours into the cup. I started to disassemble the espresso machine and the only thing I observed was that while brewing coffee, in the place where the piston squeezes the coffee disc, you can see the bubbling from the side. And this gurgling can also be heard after brewing / pouring coffee. Does anyone have any idea? Because I'm going through a bend ....
    Thank you and best regards
    Clove
  • #2 16423731
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Double tap valve, piston seals and so-called Barista or bottom piston. These items probably need to be replaced ..
    Kawa i Naprawa - Serwis AGD
  • #3 16424436
    Zabek-TimmY
    And such a question, what costs could it be? And am I able to exchange it myself or does it have to be a service?
  • Replace gaskets, clean grinder, and use Teflon grease
    #4 16425272
    nioop
    Help: 503
    Rate: 3337
    Zabek-TimmY wrote:
    And such a question, what costs could it be? ....
    My statement was purely hypothetical, that you described the problem, no one can diagnose it 100 percent .. I suggested where to look for the reasons first ...
    The leak matter itself is very simple - We look where it flows and replace this element.
    Personally, I would like to replace all gaskets in KRUPS, as you can hear bubbling, I would suggest comprehensive cleaning of the coffee grinder, because this bubbling causes moisture in the grinder and its damage at a later stage.
    O-rings themselves can be commissioned to sealing companies - The cost depends on the company and the material used, but please do not use ordinary silicone - It does not work in the long run.
    Other gaskets, unfortunately, need to be purchased from the manufacturer (or agents) and unfortunately there are a bit higher costs.
    Naturally, you need to get a screwdriver T15, T20, T10 and sometimes T8, additionally you need a certified grease resistant to water and temperature - I recommend it with the addition of Teflon.
    Zabek-TimmY wrote:
    ... And am I able to exchange it myself or does it have to be a service?
    The forum, as the department suggests, deals with small household appliances defects, not divination; p But seriously - No one can really estimate your manual skills online.
    We are happy to help as much as we can but we are not liable for damages when: "oops, broke because I was too tight"
  • #5 16426759
    Zabek-TimmY
    The coffee machine is taken apart from all external casings, so I will try to see where the leak is from and possibly take a picture and post it.
    Possible O-rings and some gaskets are able to replace myself, until such a left one is probably not :P
    As for the risk of damage to something, I am aware of it and will try to repair it.
  • #6 16780033
    dzynio
    Rate: 10
    I'll connect to the topic. I have a problem with coffee leaking under the coffee machine. Initially, it looked like a large amount of water on the boiler (where the brewing unit enters) because it was leaking up when pumping water. Exactly here marked in red:
    After reading many posts, I decided to replace the seals and clean the machine. I cleaned the brewer strainer, old coffee grinder and the whole coffee machine in general. I dismantled the piston and replaced the seals. One by one I undressed the boat (I unscrewed the piston and pulled out the sieve) and here I have a problem.
    The seal looked like it was pushed in too far. It was inserted like this:
    Close-up of a coffee machine boiler interior with visible signs of rust and a sealing element.
    Looking at various topics on the Internet I have not found specific information on how to set it up.
    How the gasket should be installed in the Krups EA8050PE espresso machine.
    Just like number 1 or number 2
    Interior view of a Krups EA8050PE coffee machine with visible deposits and a gasket.
    And which side up or vice versa:
    Rubber gasket ring with a red arrow pointing upwards.
    I put it on as in picture 1 and the larger part at the top. I also replaced the brewing unit gaskets (what goes on the piston) and you can see that the water does not collect on it anymore. However, there is still water with coffee under the coffee machine and a little to the cup but not much.
  • #7 16780092
    nioop
    Help: 503
    Rate: 3337
    It should be mounted as in picture No. 1.
    As for the leak, all that remains is an attempt to start the espresso machine without a side casing and a visual assessment of the leak.
  • #8 16780213
    dzynio
    Rate: 10
    Tests without casing and coffee (even though I click coffee to make) do not show leaks anywhere. Only what a lot of water (as I make coffee is coffee) is collected in a tray. I checked the piston in the 2 bar valve plus this small piston in the middle and it goes without problems. Still, I cleaned it.
  • #9 16786958
    dzynio
    Rate: 10
    Looking at the espresso machine without the housing, there are no leaks anywhere.
    The problem seems to me in the amount of ground coffee through the grinder. Grinding takes about 6-8 seconds and the coffee spills a lot until it does not fit in the brewing place and it spills over the coffee machine. How can this be adjusted? Reduce the amount? Is that a matter of coffee?
  • #10 16810244
    dzynio
    Rate: 10
    I write a little late but I managed to get it right.
    For others for the future.
    I replaced the O-rings on the double-tap valve piston and generally for the double-tap valve. The problem is gone.
  • #11 17595357
    Franek70
    Where did you buy the O-rings and grease? e.g. north.pl?
  • Piston rises during brew, leak not from o-rings
    #13 19075185
    George.1
    Hello. I have the same problem. The leak is exactly there.
    At first I replaced two o-rings from piston with new but the leak didn't stop.
    So, I saw better the procedure and I observed that the piston is going up when the coffee is coming to my cup.
    See the piston. You will see that the piston is coming up. So in my case the leak is not from the two o-rings on piston.
    But I can't find why is hapenning this.
    I can't find the solution.
    Is here someone who can help?
  • #14 19086889
    Franek70
    I bought a repair kit and my friend replaced it. I have the impression that the pressure is too low anyway. A different taste of coffee. The last time KRUPS has collapsed shelves on the website, they say that they are disposable.
  • Pump, flowmeter, or hydraulic spring may be causing leak
    #15 19314695
    LuisMM
    Hi George, it can normaly be various causes, normaly is a pump problem, you have to repair pump with sealant bowl and kit or a new one.
    It can be to a flowmeter problem or it can be the spring inside hidraulic with metal ring out or degradated inside.
The discussion revolves around issues with the Krups EA 8050 espresso machine, specifically coffee leakage and bubbling during the brewing process. Users report that coffee leaks inside the machine, with some coffee spilling into the drip tray instead of the cup. Common suggestions for troubleshooting include inspecting and potentially replacing the double tap valve, piston seals, and O-rings. Users emphasize the importance of cleaning the machine and ensuring proper gasket installation. Some have successfully resolved their issues by replacing O-rings and seals, while others continue to experience problems, indicating possible pump or flowmeter issues. The conversation also touches on the costs and availability of replacement parts.
