Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect
vesania 10992 13
How can I fix a Krups EA 8000 that pumps hard but makes weak coffee, releases a lot of steam from the top grille, and only improves for a couple of days after descaling?
The most likely cause is a clogged check valve / two-bar valve in the distributor, and that part usually needs cleaning or replacement rather than more descaling [#16268989] [#16269917] The valve is located at the distributor, so the problem is in the brew path rather than the descaling cycle itself [#16269917] A self-cleaning cycle may help only if the seals are not swollen, but if the valve is blocked or worn, the practical fix is service or replacing the valve [#16269917] [#16268989] The heavy steam from the upper grille fits with pressure not being routed correctly through that valve and the coffee path being restricted [#16268989]
  • #1 16268835
    vesania
    Hello, I have express as in the title. The problem is when she makes the coffee, the pump works hard, as if she wanted to but couldn't. The coffee runs very faint and is terribly lurious. The descaling only helped for two days. In addition, a very large amount of steam is escaping from the upper grille, which was not the case before. How can I fix it?
  • #2 16268989
    eldomek
    Help: 18
    Rate: 171
    Clogged check valve, only service can do it.
  • #3 16269564
    vesania
    And it is not possible to replace the valve with a new one? Where is it located - somewhere in the dispenser?
  • #4 16269917
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3339
    Yes at the distributor. Please google krups two-bar valve and see what it looks like. Self-cleaning may help without replacement as long as the seals are not swollen.
    Kawa i Naprawa - Serwis AGD
  • #5 16272143
    vesania
    Today I turned on this machine, but the Calc and Clean lights are on. When the Rinse Service button is selected, only the frothing nozzle is activated. And how do I trigger cleaning of the coffee spouts? Besides, I noticed that the entire thermo block was covered with dried coffee, as if it was dry coffee with water. So caked all over.
  • #6 16276203
    eldomek
    Help: 18
    Rate: 171
    Instead of drilling down the topic, get down to work or let the website earn money. Everything you have previously described and there are no simpler options. If you play with the coffee machine in such a state without the housing, you may get burned.
  • #7 16276674
    nioop
    Help: 503
    Rate: 3339
    A colleague above aptly, but very bluntly, realized the solution to the problem ..
    I do not really understand the description of the defect and the cleaning process is described in detail many times on the forum as well as in the manual of the equipment, warning - which is also available on the manufacturer's website.
    Everyone here is happy to help with defects, but not reading the instructions:]
    Please specify the fault and where did you encounter the problem?
  • After distributor replacement, coffee button activates frother
    #8 16294374
    vesania
    Nioop, I already explain exactly what the problem is. As in the post above, the calc and clean lights were lit. After carrying out the rinsing and descaling procedure - the machine worked reasonably okay for about two days. After that, the coffee still flew faint, was lurid and not very drinkable.
    As a colleague above suggested a problem with the double bar valve, I did not clean or replace it. I put in a brand new distributor because I had the opportunity. And now the problem is that ... I turn on the coffee machine, the equipment is getting ready for work, heats up and when it is ready, when I press the button of the coffee cup, instead of making coffee, the frother nozzle turns on automatically, and then after the frothing process is done , the machine is ready for further use. To sum up ... whether I press making coffee or the nozzle button, here and here the nozzle comes on. Only that.
  • #9 16294533
    nioop
    Help: 503
    Rate: 3339
    If the problem occurred after replacing the distributor, the only part of the game is its incorrect installation.
    Were the connectors from the microswitches disconnected?
    The distributor is sure of a specific model?
    Edit.
    As below - Theoretically, this fault is unfeasible.
    The distributor is not allowed to pair each function because his physical design does not allow him to do so:]
    Maybe photos after the assembly of the distributor? Maybe we'll see something ..
  • #10 16294538
    eldomek
    Help: 18
    Rate: 171
    I do not know such a feler. Turns out you got something wrong ... Practice makes perfect, good luck :)
  • Distributor connectors remain connected; photos show internal assembly
    #11 16305941
    vesania
    nioop ... the connectors were not disconnected from the distributor. Okay ... I'm attaching some photos. Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect Troubleshooting Krups EA 8000: Weak Coffee Flow, Excessive Steam & Short-lived Descaling Effect
  • #12 16317875
    vesania
    Or maybe someone has a hydraulic diagram for this machine, because only this frother nozzle works all the time. Nioop, you wrote that it is a matter of connecting the distributor.
  • #13 16332862
    pawel_elo
    Hello. I have a similar problem as a colleague. Coffee machine ea8050. I am still waiting for more news, especially as the topic is fresh. The coffee is flying very slowly, a lot of air in the hoses from the water tank itself (should it be like that?). No leaks or leaks. The plunger is not raised during brewing. I checked the two-bar valve - it looks ok. The seal is intact in the boiler. As for me, although I am green on this topic, everything indicates a damaged pump. A lot of water vapor is escaping from under the upper casing (I think that's the air in the hoses). Coffee machine for about 8 months and is regularly cleaned and stoned. I forgot about the warranty because I lost the proof of purchase, so please do not take it into account. All hoses inside are very clean, without limescale and dirt. If there is a need, I can record a video of how it works. HELP!
    Added after 12 [hours] 46 [minutes]:
    I hope I found the cause of the fault. Namely, after disassembling the Ulka pump, I found one broken spring that moved the piston. Does anyone know the dimensions of this larger spring? Can you buy it separately or just the entire pump? Maybe someone has to sell it, I would like to buy it at a low price :)
  • #14 16339554
    vesania
    But I have a bigger problem, because the coffee doesn't fly at all. Whatever I press, the frothing nozzle turns on and nothing else. Moreover, from what I can see, no one knows what it is about.
The discussion revolves around troubleshooting issues with the Krups EA 8000 espresso machine, specifically weak coffee flow, excessive steam, and short-lived descaling effects. Users report that the coffee is faint and watery, with the machine's pump struggling to operate effectively. A common suggestion is to check the two-bar valve for clogs, which may require professional service for cleaning or replacement. Users also mention issues with the frothing nozzle activating unexpectedly, indicating potential installation errors after replacing the distributor. Additional problems include air in the hoses and steam escaping from the upper casing, leading to speculation about a damaged pump. The conversation highlights the importance of proper assembly and maintenance, as well as the need for hydraulic diagrams for further troubleshooting.
