Filipdz wrote:Network -> ON GRID -> Off grid.
On grid sends to the network and forwards to Off grid
Off grid charges the batteries and transfers them to the house
If there is no electricity, it only works off grid and takes power from the battery + panels
So it would be a hybrid
waltergraham72 wrote:So what would it look like? Unfortunately, connecting 5kW as 1F is above the standard of 3.68kW.unless you can bridge 1 phase of the hybrid one and connect this 1 phase to 3 phases separately
waltergraham72 wrote:this is the inverter
https://easunpower.com/products/easun-power-h...50vdc-grid-tied-touch-screen-inverter-with-ct -sensor
Regards
I think it has the RCF because it says it has CT -Control Techniques. Advanced RFC control algorithm.
I guess that`s it.
rob160 wrote:These devices need to be switched to the on_grid production phase.From the DTS counter, for example, it shows about 7kW of production, home consumption of about 100W and 6.9kW of exports... At the same time, the Eastron counter connected to AC In EASUN shows about 300W of consumption (several devices)
TL;DR: Connecting an on-grid and off-grid inverter to one installation is possible; just respect the 3.68 kW per-phase export cap [PSE, 2023] and remember “Of course you can” [Elektroda, jurek.parus, post #19896867] Plan the order, certificates, and backup loads.
Why it matters: A correctly wired hybrid keeps the lights on during blackouts while still earning feed-in credits.
• Single-phase export cap: 3.68 kW per phase in Poland [URE, 2023]. • AC-coupled hybrids must meet PN-EN 50549 or VDE-AR-N 4105 [PSE, 2023]. • RfG/RfC certificate required before any grid injection; check the PTPiREE inverter list [Wykaz certyfikatów, 2024]. • Off-grid idle draw: 22-60 W (Easun SMG II datasheet, 2023). • Safe battery sizing: daily kWh × 1.2 for 80 % DoD [IRENA, 2022].
