Toshiba L4300 USB Firmware Upside Down Fix (32, 40, 50 Models): Vol. (-) & Unplug Method
makisalfa 6606 2
  • #1 19910362
    makisalfa
    Rate: 43
    UP SIDE DOWN LOADING. 32''40''50'' IT IS FOR ALL MODELS WITH L4300 MAIN. THIS FIRMWARE IS FOR A USB STICK.
    TURN OFF TV AND UNPLUG. PUSH VOLUME (- ) AND PLUG THE POWER CABLE.
    • xxx23xxx_105_REV10.bin (4.51 MB) You must be logged in to download this attachment.
  • #2 20113421
    ektwr
    Dear Makis
    I'm Greek too and I have model 50L4333 TV. I try to transfer the bin firmware file into TV with USB FAT32, but when I press the volume (-) and then plug the TV, nothing happened. Can you explain how long should I press the (-) volume button?
    Thanking in advance
  • #3 20114437
    makisalfa
    Rate: 43
    10sec. It has to be formatted in Fat32 only! After, you can unzip file into the USB. (without folder)
