Toshiba 50L4363D TV Software Update via USB: Model, Chassis, Main Board & Screen Info
bogipan 9447 4
  • #1 19969519
    bogipan
    Rate: 16
    Mark: Toshiba
    Model: 50L4363D
    Chassis (main board, components): 32L4300 1.02A
    LCD Screen/Panel (if exist):LC500DUE SFR1
    More informations: Only Toshiba logo is on the screen, TV is dead (keyboard and RC does not work)
  • #2 19969555
    billobirillo
    Help: 333
    Rate: 764
    Link
    works on W43xx L43xx L63xx L73xx M63 M83 series
  • #3 19969702
    bogipan
    Rate: 16
    billobirillo wrote:
    Link
    unfortunately unsuccessful, Starting but write: software upgrade is unsuccessful!
  • #4 19969924
    billobirillo
    Help: 333
    Rate: 764
    replace the spiflash 25Q16 with a new one, and write it with this bin file
    then retry the software upgrade
    if it still doesn't work, most likely the motherboard is damaged
    main 32L4300 REV1.02A
    panel LC500DUE-SFR1
    • IC122_25Q16.BIN (2 MB) You must be logged in to download this attachment.
  • #5 19971029
    bogipan
    Rate: 16
    This bin is already inside my 25Q16, but only TOSHIBA logo stand onto screen! When I insert USB software, result is as in the picture... probably mainboard fault Toshiba 50L4363D TV Software Update via USB: Model, Chassis, Main Board & Screen Info
    EMMC fault ?!
