Te32472s27txd Firmware Update for DTT Changes in Italy - Resolving LCN Channel Confusion
annavivaldi57 2514 7
  • Firmware update needed to fix LCN channel confusion
    #1 19952025
    annavivaldi57
    Level 4  
    I don't know if it's the correct post but by Google I have found a similar issue related to this exact model.
    I will have this TV in my room...... it works but after recent DTT changes in Italy I have a lot of issues.
    LCN made all channels in confusion....... it apparently does not work.
    I tried to look inside and my TV maybe needs a firmware upgrade? How can I check the current firmware and if it exists try to upgrade this to the latest available?
  • #2 19953483
    querij
    Help: 42
    Rate: 227
    Service menu Menu 4725
  • #3 20092501
    annavivaldi57
    Level 4  
    Ok.... But from this service menu what information can I send ??
    I have taken some photos of my TV when the Service Menu is open:
    Try to post here:
    Te32472s27txd Firmware Update for DTT Changes in Italy - Resolving LCN Channel ConfusionIMG_202207...213421.jpg (2.33 MB)You must be logged in to download this attachment.
    Te32472s27txd Firmware Update for DTT Changes in Italy - Resolving LCN Channel ConfusionIMG_202207...213445.jpg (1.67 MB)You must be logged in to download this attachment.
    Te32472s27txd Firmware Update for DTT Changes in Italy - Resolving LCN Channel ConfusionIMG_202207...213450.jpg (2 MB)You must be logged in to download this attachment.
    I can find if there exists a newer firmware that can resolve this LCN issue ?
  • #4 20093124
    querij
    Help: 42
    Rate: 227
    I will send you a file to update, but the menus may be different.
    Extract the file to a usb pen formatted in FAT32, insert it in usb1 and with the lcd on, press the following keys,
    Menu1505 and accept the prompt to update
    • MB140_Picasso_QUI_V.2.28.0 Core Update.zip (13.17 MB) You must be logged in to download this attachment.
  • #5 20093684
    annavivaldi57
    Level 4  
    mmmmmmmmmm.. it's not a trouble if then the TV continues to work.
    *EDIT*
    Other question........ does the USB formatted at FAT32 need to be empty?
    I think I need to put the .bin file included inside this zip on the main root of the pendrive......... is it correct?
  • #6 20093689
    maksar
    Help: 177
    Rate: 1030
    Malicious tip!
    do not load software of unknown origin.
    dedicated only to this model of TV.
    Greetings.
  • #7 20093694
    querij
    Help: 42
    Rate: 227
    Yes to both, if you don't recognize the update, let me know, because you may need an intermediate update
  • #8 20163084
    tecmo
    Ciao prova a fare prima il reset di fabbrica, se non l'hai già fatto, e metti tutto da capo facendo attenzione alla nazione corretta e lingua, verifica anche se la voce lcn nel menu installazione è su on fammi sapere
The discussion revolves around issues with the Te32472s27txd TV model following recent DTT changes in Italy, specifically related to LCN (Logical Channel Number) confusion. Users suggest accessing the service menu (Menu 4725) to check the current firmware version and potentially update it. Instructions for firmware updating involve using a USB drive formatted in FAT32, with specific key sequences (Menu1505) to initiate the update. There are warnings against using firmware from unknown sources and suggestions to perform a factory reset and ensure LCN settings are correctly configured.
