What cable cross-section to install in the kitchen?
Dzióbuś 1257 2
  • Modern kitchen circuit layout with dedicated 2.5 mm² runs
    #1 19969387
    Dzióbuś
    Before the renovation, I had 1 2x2.5 cable and B16 security for the entire kitchen, 2 bathrooms and 3 other rooms. Of course, there was also lighting in the same rooms. This is what it was done in the 1980s and 1990s. Luckily, these were copper, not aluminum, wires. It struck the fuse no more than once a year, but I tried not to turn on two washing machines, a kettle, an oven and a microwave at the same time ... ;)
    Now, in the kitchen itself, I threw 4 cables - sockets, 1 cable - lighting (3 rooms on this cable) plus one for a possible induction.
    And this is what it looks like:
    1. Oven, microwave - 3x2.5
    2. Fridge, landline phone, 1 free - 3x2.5
    3. Dishwasher, hood, LED under-cabinet lighting - 3x2.5
    4. 3 double sockets above the table top, plus one free one by the window - 3x2.5
    5. Possible induction, although it will probably never be there, because I prefer the gas hob, but it's better to do it now, because the next renovation will not be earlier than in 20 years :) - 5x2.5
    6. Ceiling lighting - 3x1.5
    Will be OK?
    Moderated By krzysiek7:
    I separated from https://www.elektroda.pl/rtvforum/topic2903447-30.html
    3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • Separate kitchen loads onto dedicated circuits
    #2 19969460
    kokapetyl
    Help: 1787
    Rate: 2102
    Dzióbuś wrote:
    Now I have put 4 cables in the kitchen alone
    This is no revelation. :D .
    And a few comments.
    1. any consumer with higher power, is to have a separate power supply (combining the microwave with the oven, not correct).
    2. lighting is not to be combined with socket circuits (Dishwasher, hood, under-cabinet lighting, not correct)
    3. 1 cable - lighting (3 rooms on this cable), I also have reservations,
    Dzióbuś wrote:
    Will it be ok?
    I guess you can answer that question for yourself. :cry: .
  • #3 19969464
    sebek3
    Level 30  
    Help: 125
    Rate: 343
    Under-cabinet lighting with a cooker hood is fine, as there will probably be a power supply plugged into the socket, and it is not the main lighting but rather decorative or used for cooking etc., but the dishwasher should be on a separate circuit. Any load >2kW should have a separate circuit and protection.
