Choosing the Right Cable Cross-Section for Kitchen Appliances: Fridge, Stove, Oven
malina998 64764 30
How should I choose the cable cross-section and circuit protection for kitchen sockets feeding a fridge, a gas-electric cooker, an electric oven, and other small appliances?
Split the kitchen loads into separate circuits instead of putting the fridge, oven, cooker and general sockets on one line; any receiver above about 2 kW should have its own circuit, and the socket circuits should also be protected by an RCD [#13991458] For an ordinary gas cooker with only electric ignition, a separate 3×2.5 mm² circuit with B16 protection was judged sufficient [#13991557][#13992798] For the oven, follow the manufacturer’s connection instructions and rated power rather than guessing from shop tables; the thread notes that many single-phase ovens are supplied for a normal 16 A socket, while higher-power versions need a dedicated supply [#13991416][#13991495] If you want room for future changes, one reply also suggested running a spare 5-core cable near the cooker [#13991771]
  • #1 13991308
    malina998
    Rate: 44
    Hello everyone, quite late everyone. :)
    I need a short hint and advice on the conductor cross-section. It is about sockets in the kitchen, 3 or 4 sockets to be exact. The receivers are, of course, a fridge-freezer, a gas-electric stove (power according to the tables from 2 to even 5.9 kW depending on the manufacturer), an electric oven (power 2-3.6 kW) and of course some smaller household appliances such as a blender, etc.
    3x2.5mm? or 3x4mm ?? I would divide it into two separate circuits with B16 protection for each, and 3x2.5mm? Wires. Correct?
  • #2 13991319
    Darkdarkman
    Level 30  
    Help: 120
    Rate: 253
    Clamps under the gear usually allow a maximum clamping of 2.5mm?
  • #3 13991326
    malina998
    Rate: 44
    Mhm. Fact. I got Babola! I'm ashamed. :oops:
  • #4 13991332
    olejopalacz2
    Help: 32
    Rate: 159
    5x2.5mm for the oven, separate fridge, separate dishwasher, separate sockets, 3x2.5mm ??.
  • #5 13991340
    malina998
    Rate: 44
    olejopalacz2 wrote:
    For the 5x2.5 oven,
    All devices are single-phase.
  • #6 13991346
    olejopalacz2
    Help: 32
    Rate: 159
    Pull 5x2.5mm under the stove? It will be better and with a spare.
  • #7 13991381
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    For the stove-oven, give 3 × 4mm?. The 16A fuse is definitely too small. 2.5mm? cross-section and the 16A fuse, we use up to 3.5KW - if the power consumption is to reach ~ 6KW, then 25A will be on contact.
  • #8 13991396
    malina998
    Rate: 44
    Will 4mm? be pressed into the socket terminal?
    Colleagues, how do you connect nests from practice? Separate power cord for each or in parallel?
  • #9 13991409
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    If I understand correctly, you want to connect the cooker to the schuko socket!
  • #10 13991415
    malina998
    Rate: 44
    If the plug is also schuoko then yes. I have not checked what plugs have cookers or an oven so far.
  • #11 13991416
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    For three-phase electric kitchens I give 5 × 4mm? And for single-phase 3 × 6mm? with a protection of 25A.
    Added after 6 [minutes]:
    malina998 wrote:
    If the plug is also schuko, then yes. I have not checked what plugs have cookers or an oven so far.
    With a power consumption of more than 2.5, or up to 3kW, you cannot use a plug-socket! They are adapted to a MAXIMUM of 16A!
  • #12 13991458
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    First of all, what are we meant by "gas-electric stove"? Got it gas hob with electric oven - right? If not, please specify. Enter the model, type, manufacturer name. What connection power do you have? If this data is known, we can further discuss.
    Any receivers above 2kW (dishwasher, washing machine, oven) should be on separate circuits. General sockets in the kitchen as well.
    Needless to say, the socket circuits should be additionally protected with an RCD.
    psilos1 wrote:
    For three-phase electric kitchens it gives 5 × 4, and for single-phase 3 × 6 kitchens with 25A protection
    25A on one phase in Polish home conditions - you deign to joke.
    And here my friend contradicts himself:
    psilos1 wrote:
    With a power consumption of more than 2.5, up to 3KW, you cannot use a plug-socket because they are designed for a MAXIMUM of 16A!
    and
    psilos1 wrote:
    2.5mm? cross-section and a 16A fuse can be used up to 3.5KW
    Make up your mind finally. Or maybe you'd better stop writing nonsense already.
  • #13 13991472
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    16A at 230V is a maximum of ~ 3.6KW - we are not talking about a kettle but about an electric stove-oven that can be turned on for hours.
    The electric kitchen I have consumes a maximum of over 5KW ... single-phase installation ... according to the respected moderator, what sections and protections should it have?
    They taught me in the energy sector that 5KW is over 20A ...
    Added after 14 [minutes]:
    The privilege to be a moderator does not justify the use of such vocabulary! If you do not agree with me, please write culturally - do not be offended !!
  • #14 13991487
    Łukasz-O
    Help: 654
    Rate: 4290
    Oven on for hours? I thought we were talking about an apartment, not a bakery and confectionery cooperative.
    Forgive me, but a single-phase electric cooker with a power of 5kW is absurd in Polish home conditions.
    After that, the author wrote about a gas-electric stove. I believe the first power (of the kitchen) is for gas. The second is the oven. Oven (as a rule) terminated with a cord with a regular plug adapted to a 16A socket. That is? Still saying you should route 3x6 wire and secure 25A? It is different if the equipment does not have a plug. Fortunately, each device has instructions where we can find guidelines.
    Sorry, but how else to call two contradicting theories expressed by the same man within a dozen or so minutes?
  • #15 13991488
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    malina998 wrote:
    (Power according to the tables from 2 to even 5.9 kW depending on the manufacturer)
    In my posts, I responded to the above statement by the author ...
    As for the electric cooker and oven - how many non-stop hours are included, for example, before Christmas?
  • #16 13991495
    Łukasz-O
    Help: 654
    Rate: 4290
    I will quote the whole:
    malina998 wrote:
    , gas-electric cooker (power according to the tables from 2 to even 5.9kW depending on the manufacturer), electric oven (power 2-3.6kW)
    Do you see an inaccuracy?
    I do not keep such statistics. Did you see the cross section of the oven power cord? Enter the value of the protection recommended in the manual and the requirements for the installation. We are talking all about home appliances available on the Polish market.
  • #17 13991557
    malina998
    Rate: 44
    When it comes to the gas-electric stove, I mean an ordinary stove with the so-called ignition / spark gap, which works while being energized and probably that's it. I'll find out what they really want. I took the data from one of the household appliances stores. As for the oven, it will be built-in.
    All single phase devices and there will never be any induction there which requires 3 phase installation.
    The RCD will, of course, be there.
  • #18 13991771
    jack63
    Help: 851
    Rate: 2822
    Does the magneto need 5.9 kW of power ???
    Not necessarily. Depends on the type / manufacturer. Mine has a maximum of 7.8 kW and a power supply from two phases.
    Of course, it did not have a plug, but the electric oven (probably 3.5kW) did have a plug.
    There is a problem with this data before buying. Merchants know the button. Marketing teasers are not very meaningful. Most often, we find out about what we stand ... after the purchase, reading (if someone is reading?) The manual, and the installation must already be done.
    To get ready for contact, you need to download the instructions from the Internet or pick it from the packaging in the store, but you have to be sure of the choice of the device, which is difficult ..... A woman is changeable and the market situation is also changing.
    Because what if you want an induction hob at the last minute?
    According to it is better for me to lead a 5-core cable near the oven, as my colleagues suggested. Even if 2 cores will "stick", in a few years, when changing the design, you will not have to replace the installation.
  • #19 13991802
    Darkdarkman
    Level 30  
    Help: 120
    Rate: 253
    Or maybe fly right away with busbars and BMy to it?
    Plus some little nuclear power plant in the basement?
    Moderated By Akrzy74:
    3.1.11. It is forbidden to publish entries that do not contain substantive content, contain harmful advice, advice that is not an attempt to solve the problem, and the publication of identical entries consecutive or repeating information from the discussion.
    Next time a colleague will receive a warning.
  • #20 13992055
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    I have a cwaniaczku, this is the stove: Choosing the Right Cable Cross-Section for Kitchen Appliances: Fridge, Stove, Oven
    The installation is of course single-phase ... I have it connected 3 × 6 with 25A protection. (Single-phase connection 63A) Maybe you can explain to me what I am doing wrong ... I finished energy technical college over 20 years ago, so maybe something has changed during this time?
    Moderated By kkas12:
    3.1.9. It is forbidden to disseminate ironic, mocking or malicious content that shows disrespect for other Users or third parties.
    Warning # 2.
    For the "trickster".
    In addition.
    3.1.13. It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible.
  • #21 13992071
    zbich70
    Help: 1171
    Rate: 6666
    psilos1 wrote:
    One-phase installation, of course ... I have it connected 3 × 6 with 25A protection. single-phase connection 63A )
    But in Łódź or Athens?
  • #22 13992136
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    In this case, in Athens ... but that's not the point - the topic is the appropriate selection of the cable cross-section for the power consumption of the device and for the appropriate protection. Example: during the renovation of my mother's house, a professional electrician gave 3 × 2.5 with protection 16A !!
  • #23 13992173
    Darkdarkman
    Level 30  
    Help: 120
    Rate: 253
    At home, you can even hack 3x16 if you have such a fantasy.
    For 3x6, the permissible long-term load capacity, depending on the arrangement, is much more than 40A.
    Unless you have 300 meters of this cable for the stove.
  • #24 13992200
    zbich70
    Help: 1171
    Rate: 6666
    psilos1 wrote:
    The topic is the selection of the cable cross-section to the power consumption of the device and the appropriate protection.
    So in order to choose cross-sections and protections (and install receivers with significant powers) you first need to know the WTP and the connected power.
  • #25 13992798
    Łukasz-O
    Help: 654
    Rate: 4290
    What does that have to do with this topic?
    Does the author connect the terma? He writes about an ordinary gas stove with an electric oven. A separate 3x2.5mm? circuit secured by a B16 switch is enough.
  • #26 13996870
    malina998
    Rate: 44
    Wires spread out. Now I'm just waiting for the development project to come, i.e. where, what cabinets and how to decide where what should stand. I have always had the opinion that renovation and, in addition, one room is worse than war :D I made 3 circuits secured with B16 switches. The location of the existing switchgear, and at the same time the lack of space to add even one apparatus, is also the best that can be. But no one said it would be easy and fun.
  • #27 13996888
    Łukasz-O
    Help: 654
    Rate: 4290
    Larger switchboards can always be installed :D
    It is a pity that you did not write what the circuits are and whether they are protected by a residual current device.
  • #28 13996910
    malina998
    Rate: 44
    Oh, believe that you can't get more ... I had to take the paneling of the bottom of the stairs apart, because the masking frame wouldn't come out :D I added a surface in the only possible place.
    In general, fortunately, it is still far from connecting all this and I still have to rework this switchgear. There is one RCD 40A in the current old switchgear. Powered by 3 phases. And here, as a curiosity, I will write that the power supply is at the top, the load is at the bottom, but also at the bottom.
    I knew it would be economical, but I didn't think it would be that much. Arguments are useless ...
    "so far it will continue to work". And that's it.
  • #29 13996965
    Łukasz-O
    Help: 654
    Rate: 4290
    Bad reasoning. In addition, a three-phase RCD for everything, it will take revenge sooner or later.
  • #30 13997165
    malina998
    Rate: 44
    We know it. But others, unfortunately, do not. In the event of a breakdown, the entire house is left without power. However, I will try to break through some reason and I would split it into 3 single-phase RCDs.
    Managed to. There will be 3 RCDs 25A 0.03A. This RCD 40A will be fired. As the current equipment is Hager, I will also look for this company. Only the Schneider switches will hurt your eyes :)
The discussion revolves around selecting the appropriate cable cross-section for kitchen appliances, specifically for a fridge-freezer, a gas-electric stove, and an electric oven. Participants debate between using 3x2.5mm² or 3x4mm² cables, with suggestions for separate circuits and appropriate protection (B16 fuses). Key points include the need for separate circuits for high-power devices (over 2kW), the importance of adhering to local electrical standards, and the necessity of using RCDs for safety. The consensus leans towards using larger cross-sections (3x4mm² or 5x2.5mm²) for higher power demands, especially for the stove and oven, while ensuring compatibility with socket terminals.
TL;DR: 3.6 kW (16 A at 230 V) is the safe ceiling for a 3 × 2.5 mm² circuit, and "a separate 3×2.5 mm² line on B16 is enough" [Łukasz-O, #13992798]. Split every ≥2 kW appliance onto its own breaker. Why it matters: right-sizing stops melted wires and mid-cook shutdowns.
• 3 × 2.5 mm² Cu + B16 A → up to 3.6 kW continuous [psilos1, #13991381] • Schuko plug/socket rated 16 A max; avoid loads over 3 kW [psilos1, #13991416] • 5-core 2.5 mm² feed keeps option for future induction hob [jack63, #13991771] • RCD protection ≤30 mA required on all kitchen socket circuits (PN-HD 60364-4-41)
What cable cross-section is enough for a domestic fridge?
A fridge rarely exceeds 300 W, so a standard socket on a 3 × 2.5 mm² circuit with a B16 breaker is more than adequate [malina998, #13991308].
Do gas hobs with electric ignition need a thick supply?
No. Ignition and oven lighting draw under 100 W. They can share a 3 × 1.5 mm² lighting/socket circuit, but most installers still use 3 × 2.5 mm² to keep wiring uniform [malina998, #13991557].
Which cable and breaker for a 3.0–3.6 kW built-in oven?
Use a dedicated 3 × 2.5 mm² copper cable protected by a B16 A breaker. This keeps current below the 16 A Schuko and conductor limits [Łukasz-O, #13992798].
When must I step up to 3 × 4 mm²?
If the single-phase appliance exceeds 3.6 kW or the run is unusually long (>25 m), move to 3 × 4 mm² with a B20–25 A breaker to stay within voltage-drop and thermal limits [psilos1, #13991381].
Why is a Schuko plug unsafe above 16 A?
Schuko contacts are rated 16 A continuous. At 20 A they overheat; tests show terminal temps can climb past 80 °C in minutes, a fire risk [psilos1, #13991416].
How many separate circuits should a modern kitchen have?
Plan at least four: 1) fridge, 2) dishwasher/washing-machine, 3) oven/hob, 4) general work-top sockets. Each on its own B16 and 30 mA RCD [Łukasz-O, #13991458].
Is running a 5-core cable now worth it?
Yes. A spare 5 × 2.5 mm² lets you switch to a two-phase or three-phase induction hob later without ripping walls [jack63, #13991771].
What breaker pairs with 2.5 mm² aluminium conductors?
Aluminium carries less current. Limit to B13 A or upgrade to copper to avoid hot joints. IEC 60364 tables give 18 A max for 2.5 mm² Al in conduit (edge-case).
How do I convert kW to required cable size fast?
  1. Divide power (kW) by 0.23 to get current (A).
  2. Pick the nearest breaker rating ≥ current.
  3. Choose cable cross-section that carries that breaker’s current per IEC tables. "Always check voltage-drop on runs over 30 m" [Expert Note].
Can I swap screw-in 10 A/16 A fuses for ‘S’ breakers one-to-one?
Usually yes—match the current rating (10 A→B10, 16 A→B16). Verify the prospective short-circuit current and install a DIN rail holder if the old board lacks one [dariusz1209, #14022141].
Do I really need multiple RCDs?
Yes. One 3-phase RCD for the whole house causes full blackout on a single fault. Splitting into three 25 A, 30 mA single-phase RCDs localises trips [malina998, #13997165].
What happens if I oversize the cable, e.g., 3 × 6 mm² on 25 A?
Nothing harmful electrically, but you waste copper and face bulky terminations. Acceptable only when supply capacity (≥63 A) supports it [psilos1, #13992055].
