[Solved] Funbox 3.0 - How to enter your own DNS addresses when the field is gray?
techus 8967 4
  • #1 20103636
    techus
    I have a problem with changing DNS in Funbox. The input field is gray. Anyone have any advice?
    Thanks in advance.
  • Funbox 3.0 uses fixed Orange DNS servers
    #2 20103929
    Bródka
    Help: 900
    Rate: 723
    Have you read this?
    Modems/routers
    If you have a Funbox 3 or Funbox 6 device, you don't need to do anything. In the settings of these devices, Orange Polska IP addresses are permanently embedded. Reason? Safety, of course. In the era of widespread network scanning for devices accessible from the Internet, preventing the replacement of DNS servers reduces the risk of a successful attack of this type to zero.
    If you use other devices, it is not possible to provide detailed instructions, but the steps you need to follow will probably be similar to the following:
    Log in to the administration panel
    Most often, this requires entering the address 192.168.1.1 in the browser
    Login (in many cases it is permanent and reads "admin" ;) and password can be found in the device manual
    Find the menu item/Network tab
    Locate the DNS section with the main/primary and secondary/secondary entries
    Enter the IP addresses provided at the beginning of this material
    Source
    KOCUREK1970
    Help: 3861
    Rate: 5489
    @Bródka
    This is about the gambling law and that's all.
    Therefore DNS blocked.
    Since when has any operator cared about customer safety? :D .
    They secured DNS, but gave access to the GUI in the router :D - yes, everyone is safe there.
  • #4 20518995
    techus
    Damn, it's a pity, because I wanted to set up Pi-hole. Well, nothing.
  • #5 20518999
    techus
    I didn't solve it.
