Best Practices for Wiring Access Points: Wall Jack on Ceiling vs RJ45 Termination
ayumi37 1266 2
  • #1 20187974
    ayumi37
    I'm having my house wired soon (finally) and have found a local CCTV company who can also do networking. I'm curious about the best practice for wiring access points. Is it normal to have a wall jack on the ceiling and a short patch cable or is the cable terminated with an RJ45?
  • #2 20189627
    KOCUREK1970
    Help: 3860
    Rate: 5488
    ayumi37 wrote:
    Is it normal to have a wall outlet on the ceiling and a short patch cord
    Come on, you don't!
    ayumi37 wrote:
    or is the cable terminated with an RJ45 connector?
    Yes.
  • Recommend wall sockets and dense AP placement
    #3 20190552
    IC_Current
    Help: 1499
    Rate: 2521
    ayumi37 wrote:
    I am curious about the best practices for cabling access points
    The best practice is to run cat 6 cables to all stationary devices and make wall sockets. And access points only as a flower for a sheepskin coat, etc. In addition, the number and arrangement of points so that there is no more than one thin wall between each point and the client device, because the WiFi radio signal with DECENT parameters usually cannot overcome more.
