[Solved] Routing Ethernet Cable from Existing Wall Sockets to Computer Room in Apartment
grejfrut12 16590 8
  • Use existing sockets to extend Ethernet run
    #1 19520790
    grejfrut12
    I have recently received an apartment and I will start finishing it. Unfortunately, at the stage when it was possible to submit changes, I did not think about adding an ethernet socket in the place where the computer will be located. The developer placed a place for the router in the box above the door and from there in the wall he routed the cable to the living room where there are two sockets.
    I would like to run a cable from these two sockets to the room where the computer is located. I would prefer not to forge in the wall from the box in the door, just use these two sockets. I thought about drilling a hole next to them as for a socket, somehow connecting it to the patch cord going to the ready socket and under the panels or skirting board, pulling the cable into the room. Drill a second hole there and insert a normal socket in the wall. Is such a procedure possible? Maybe you have another, better idea?
  • #2 19520799
    jprzedworski
    Help: 758
    Rate: 828
    grejfrut12 wrote:
    pulled the cable into the living room where there are two sockets.
    One cable and two sockets? It won't work like that. Each socket must have its own separate cable to a central point.
  • #3 19520800
    grejfrut12
    It's possible there are two. I haven't disarmed this socket yet. Anyway, from one of these sockets I wanted to somehow run a cable to the other room
  • Check for two cables before rerouting Ethernet
    #4 19520856
  • Proposed hidden Ethernet run via wall boxes and coupler
    #5 19520931
    grejfrut12
    _cheetah_ wrote:
    1. If there are two cables going to the living room, you can:
    And disconnect one of them from the socket in the living room and simply extend it to the other room, or,
    i.e. "rigidly" I buy a long ethernet cable, plug it into the socket, put it under the panels or in the strip and pull it all the way to the computer? I don't think it will be very aesthetically pleasing if the cables stick out of the floor like that.
    Generally, I do not need a second ethernet socket in the apartment. I connect to the TV via WIFI and that's enough. All he needs is behind a computer. I wanted to do it as neatly/aesthetically and non-invasively as possible. I also thought about:
    1. Unplug the cables from one ready socket
    2. Forge a box near this socket
    3. Connect the disconnected cables to link
    4. Buy a long patchcord, also 5e, and plug in the same plug on one end as in point 3.
    5. Connect the cable prepared in points 3 and 4 in the box with a connector (barrel).
    6. Run the other end of the cable from point 4 into the other room
    7. Forge a second box there and buy an ethernet 5e wall socket to which I will plug the other side of the cable.
    8. Plaster the box from point 3
  • Surface-mounted keystone and conduit for neat cable run
    #6 19521054
  • Need a switch if the AP has no LAN ports
    #7 19521106
    KOCUREK1970
    Help: 3860
    Rate: 5488
    So the damping of the box itself, walls, distance to the TV / set-top box, and you:
    Let your assumptions not be painfully verified.
    Of course, you will be able to connect an AP to a socket and take wifi to the TV from it, but you may need a switch because there will be no LAN ports in the socket, this AP must also be mounted somewhere to be effective (ceiling?), Powered somehow ...
  • #8 19521924
    jprzedworski
    Help: 758
    Rate: 828
    The TV usually has two connections. You can connect Smart TV functions (Youtube, VoD, etc.) via Wi-Fi. How's your TV? Providers over fiber generally use a dedicated VLAN to which the set-top box is connected. You can't connect this VLAN via Wi-Fi, it requires a separate cable - twisted pair.
  • #9 19736789
    grejfrut12
    I finally ran the cable under the panels and it works flawlessly
The discussion revolves around the challenge of routing an Ethernet cable from existing wall sockets in a living room to a computer room in an apartment. The user seeks a non-invasive solution without extensive wall modifications. Responses suggest checking the number of cables connected to the living room sockets. If two cables are present, one can be extended to the computer room, or a switch can be used if only one cable is available. Suggestions include using surface-mounted housings for sockets to minimize drilling and maintaining proper cable management to avoid aesthetic issues. The user ultimately reports success in running the cable under the panels.
