JBL Free X Headphones Not Charging: Right Earbud Issues & Troubleshooting Tips
Nika1019 27825 4
  • #1 18652373
    Nika1019
    Rate: 8
    I got the jbl free x headphones, I checked them, they worked great, I charged them, the charging case too, I put them in the charging case. They were there for a few days, today I wanted to start and the right handset does not turn on. When I plug it in to charge it stays on for a while then turns off. Please help, I do not have a receipt, so the complaint is out :(
  • #2 18652576
    tza
    Try replacing the USB cable... maybe there is a problem with it.
  • #3 18652942
    Nika1019
    Rate: 8
    I just replaced the cable, the charging case is charged and I put on the headphones, the right one will light up for a moment and stop lighting and the left one is charging.
  • #4 19088122
    Tomekkk87
    Hello, what did you find out because I have the same problem.
  • Check contacts and measure earbud battery voltage
    #5 19088468
