ERGOSTELLAR Premium Ergonomic Chair - User reviews and experiences, max. 2600 zł
xyz1986 6681 4
  • Physio check recommended before buying a chair
    #2 20364728
    n.vision
    Help: 108
    Rate: 260
    You know what, maybe a stupid question, but have you been to a physio with your spine? It seems to me that a comfortable chair can make the problems even worse, because it takes your attention away from the real ones like too much muscle tension e.g. due to stress or other similar things.
    Higher models of chairs mainly offer better workmanship, e.g. high-end synthetics instead of eco leather and many adjustment options, but in terms of comfort it's best that you sit on it. In general, chairs do not improve the situation with the spine, although having more adjustability is easier to set it under you. As I wrote, a very comfortable chair can at most hide back problems temporarily, but the solution most often is to introduce some exercises or change some habits. So if you want a comfortable chair, I'm afraid you have to sit on it, the price I would not suggest
  • #3 20364761
    xyz1986
    Thanks but the part you write about is behind me, I just want to keep potential future problems to a minimum :) .
  • Ergostellar identified as rebranded GTChair model
    #4 20503198
    WikKrim
    Level 4  
    >>20364673
    I've been looking for a nice ergonomic chair for myself and I've been thinking about this ergostellar because overall it's nice, but somehow I couldn't find anything about it anywhere except on this site, but finally I found it:
    https://www.gtchair.com/production/28
    https://www.gtofficechair.com/quality-1406427...le-ergonomic-chair-lumbar-support-3d-headrest
    I also found the same in komputronik for 1500 but under the name SPC Gear EG950:
    https://www.komputronik.pl/product/658676/spc-gear-eg950-ergonomic-chair.html
    It's a regular Chinese only they change the names. I don't know if it's worth the price, but for a Chinese it's a high price and a lot of things are puzzling e.g. like the 60-month warranty. Therefore, I will decide rather patriotically on the Polish manufacturer V-master:
    https://diablochairs.com/diablo-v-master
    On oleole I saw even for 2000zł. There is a lot of material and reviews about it and about all the shortcomings you can easily find out.
  • Seat too low and mesh sags under 100 kg
    #5 20623006
    jarecki753
    As I have, I koupluj home furniture, generally the chair cool, quiet nothing crackles, you can adjust cool back, lumbar BUT - BUT: too low for a man of 181cm - I had to buy pillows for the armrests on Aliexpress, plus I have a mesh seat and this is a disadvantage for me, because at about 100kg of my weight the mesh collapses slightly and you sit a little like on the loo, and to avoid this I put on the seat 2 pillows from Ikea plus an old pillow. However, it's not very comfortable and now I'm looking to change this seat to a fabric one, because I think it will be much more comfortable.
