  • #1 20373224
    przemekkucybala
    Denon avr x4100w totalny brak dźwięku w jakiejkolwiek konfiguracji, niby wszystko klika a nic nie słychać. Nie ma również diody standby, mimo podłączonego zasilania.
  • #2 20377603
    aaanteka
    Help: 729
    Rate: 1193
    What preliminary measurements did you make yourself?
    Because the description of the symptoms is not enough. Based on it, you can only make a diagnosis "broken" :) .
    przemekkucybala wrote:
    like everything clicks
    So what do you think all this is?
    Added after 5 [minutes]:
    The service manual is generally available - you need to look at it.
  • #3 20380603
    przemekkucybala
    I did everything what says in the manual, checked every possible source and checked different speakers and wires, and still have picture but no sound,
