Canon IP7250 Printhead Issue: Cyan Color Missing Despite Changing & Cleaning Cartridges
Jacksoft87 1185 0
  • Suspect printhead or motherboard fault after blackout
    #1 20464454
    Jacksoft87
    Good day everyone,
    last day I had a strange problem with my Canon IP7250.
    First of all I use mostly compatible ink cartridges, the same brand for 2-3 years without any problem and I had a blackout in the morning (but the printer was in sleep and I had a power surge protector by APC too to reduce any power-related risk).
    I had to print something and the print got with lines. Guessing the cyan ink tank was empty I was right, but when I changed it I figured that also ALL other tanks were empty, so I replaced them all.
    Made a print test with some of that pics that have all color scale and the cyan was totally missing. I reset the cartridge, made a deep clean, replaced the cartridge and cleaned the printhead with isopropyl alcohol too without any luck: cyan is still missing, no one dot or line of color.
    As last thing that I could think to do I gently disassembled the printhead by removing the 2 screws that hold them things to the plastic and made a better clean with isopropyl alcohol. Now ALL colors are gone and the only that still print is the black used for text (PGBK). It's like the printhead don't pump colors anymore.
    And the stranger thing is that there is NO blink error code or alert/error message on PC (tested on two computers)! It just prints blank.
    I decided to buy a refurbished/something like printhead from AliExpress (~42€), but the insertion says that I need to check if the motherboard is ok because it can burn the printhead (in case of missing colors!), if so I should buy a new motherboard too (that would become expensive, I guess).
    Before attempt anything other there are some tests, measurement or fix on the printhead or motherboard?
    Thank you all.
    Here the EEPROM log (just censored the SN and MAC)
    iP7200 SN=********** EUR V1.101 ST=2018/06/17-19:28 LPT=2023/02/28-00:14
    D=045.9 Ps=000.7
    DL=00067
    ER(ER0=1682 ER1=1401 ER2=1680 ER3=C000 ER4=5100)
    PC(M=001 R=001 T=092 D=000 C=038 I=006)
    TPAGE(TTL=05254)
    CH=021
    CT_STD(PBK=007 BK=009 Y=009 M=010 C=010)
    CT_MIN(PBK=001 BK=001 Y=001 M=001 C=001)
    IL(PBK=02 BK=02 Y=02 M=02 C=02)
    P_ON(S=00200)
    A_REG=1 M_REG=0
    IF(USB2=1)
    FR PAGE1(All=00151 Photo1=00140 Photo2=00008 Photo3=00000
    Matto=00000 PC=00000)
    FR PAGE2(All=05052 PP=04841 Photo1=00050 Photo2=00000 Photo3=00063
    Matto=00096 EV=00000)
    EDGE=00174 L=00000 4x6 KG=00151
    CDR=00051 CDRP=(-0352, 0078) CDRS=(0049)
    LF=* EJ=*
    INK_OFF(PBK=0 BK=0 Y=0 M=0 C=0)
    INK CLR=00
    EROM CLR=00
    WL-LAN=(MAC:**************)
    LP_WL=05254
    FER(FER0=0000 FER1=0000)
    CER(CER0=0000 CER1=0000)
