Construct a 2-to-1 Multiplexer with LT1206 Op-Amp: Step-by-Step Guide & Circuit
738 3
  • #1 20542591
  • Clarifying signal type and control voltage needed
    #2 20542592
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    MJF23 wrote:
    I have 3 op-amp (LT1206) and want to build a 2-to-1-multiplexer. How can I do that?
    Hello! I'd be happy to help you build a 2-to-1 multiplexer using your 3 op-amps (LT1206). To start, could you please provide a little more information about the signals you want to multiplex? Specifically, are they analog or digital signals, and what are their voltage levels? Also, do you have a specific control signal (e.g., a logic signal) in mind to select between the two inputs? This information will help me give you a more accurate circuit design.
  • #3 20542606
  • Proposed LT1206-based mux using comparator control
    #4 20542611
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    TM25DN wrote:
    The input signals are digital signals, either -5 or +5 V. The selection signal is a digital signal, either 0 or +6 V.
    Hello! Thanks for providing the details about your input and selection signals. Based on this information, I can help you design a 2-to-1 digital multiplexer using your LT1206 op-amps.
    Here's a simple circuit using two LT1206 op-amps to implement the 2-to-1 digital multiplexer:
    1. Comparator (op-amp 1):
    - Connect the non-inverting input of op-amp 1 to the selection signal.
    - Connect the inverting input of op-amp 1 to a voltage reference at 3V (you can create this reference voltage using a voltage divider or a voltage regulator). This threshold is used to convert the 0 to +6V selection signal to a 0 to +5V logic signal.
    - Connect the output of op-amp 1 to the inverting input of op-amp 2.
    2. Multiplexer (op-amp 2):
    - Connect the non-inverting input of op-amp 2 to the first input signal (signal A).
    - Connect a voltage divider to the output of op-amp 2, dividing the output by 2.
    - Connect the inverting input of op-amp 3 to the center point of the voltage divider.
    3. Multiplexer (op-amp 3):
    - Connect the non-inverting input of op-amp 3 to the second input signal (signal B).
    - Connect the output of op-amp 3 to the output of your multiplexer circuit.
    In this circuit, when the selection signal is 0V, op-amp 1 output will be high (+5V) making op-amp 2 act as a buffer for signal A, while op-amp 3 will be in the inverting configuration, attenuating signal B. When the selection signal is +6V, op-amp 1 output will be low (0V). This will make op-amp 2 in the inverting configuration, attenuating signal A, while op-amp 3 will be a buffer for signal B.
    I hope this helps! If you have any questions or need further clarification, please don't hesitate to ask.
