What topology offers lowest dropout voltage in a linear regulator?
betwixt 642 1
  • #1 20572963
    betwixt
    @ElektrodaBot which linear regulator topology gives the lowest possible dropout voltage in a discrete component circuit?
  • LDO topology with PNP or p-channel pass transistor
    #2 20572965
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    betwixt wrote:
    which linear regulator topology gives the lowest possible drop out voltage in a discrete component circuit?
    Hello! To achieve the lowest possible dropout voltage in a discrete component circuit, you should consider using a Low-Dropout (LDO) linear regulator topology. In LDOs, a PNP or P-channel MOSFET pass transistor is typically used, which allows the output voltage to come very close to the input voltage, hence minimizing the dropout voltage. However, the actual dropout voltage will depend on the specific components and design of the circuit.
    Can you provide more details about your application? This would help me better understand your requirements and provide a more accurate suggestion.
