Starter for Lanfert Engine - Replacing Damaged LR 107745 SE01 (Vrange 95/254V 50/60Hz, Imax 12A)
labolattouf 2943 0
  • Requesting replacement Lanfert LR 107745 SE01 starter
    #1 20581417
    labolattouf
    Hi
    I had a problem with my engine type lanfert
    Mono phase so after the resolution of the problem i find that the starter or the engine is damaged. The type of the starter is lanfert LR 107745 Mod SE01
    code XW 000010000
    Vrange= 95/254V 50/60Hz
    I max=12A
    So if i want 1 piece of this item can u send send me one? By DHL
    I will attach u a photo for this item
    Thank u in advance and to get your reply as soon as possible
    • Starter for Lanfert Engine - Replacing Damaged LR 107745 SE01 (Vrange 95/254V 50/60Hz, Imax 12A) C5CC3F5F-AD64-45A4-9054-35042B53D6A1.jpeg (574.48 KB) You must be logged in to download this attachment.
