ELNA SZ 120/125 Bench Grinder: Hums, Turns Dial, Stops - Capacitor & Winding Issues, 230V, 4uF
zlotowinfo 10920 13
How can I fix a 230 V single-phase bench grinder motor that hums, nudges the spindle, and then stops, and should I test it by disconnecting the capacitor or starting it by hand?
The most likely fix is mechanical: on these single-phase grinders, worn bearing seats can let the rotor shift out of alignment with the stator, so the motor hums and will not start; one suggested repair is to fit slightly wider bearings (for example 62201 instead of 6201) and, if needed, machine the rotor where the bearings sit [#16481475] Disconnect the capacitor and measure continuity of both the working and auxiliary windings to check that they are intact [#16479802] Winding resistance only shows that the coils are not burnt through; it does not prove the values are correct [#16480120] Starting it by hand with the capacitor removed is not a real fix and would require impractically high speed to get it moving [#16479802] The bearing condition should also be checked, because a bad fit there can be the real cause even when the windings and capacitor seem OK [#16480177][#16481475]
  • #1 16479744
    zlotowinfo
    Help: 7
    Rate: 59
    When turned on: it hums, gently turns the dial in the right direction and stops.
    After spinning the dial and turning it on: it stops.
    At 230v voltage input: 27ohm
    On the leads to the capacitor 57ohm (capacitor disconnected)
    The capacitor is functional, as on its housing, is 4uF
    Insights after reading similar threads:
    If I understood the tips on the forum correctly, it is rather winding.
    Someone wrote that if a capacitor fell, after turning it off, it would start.
    And what now:
    1. can it be fixed at all?
    2.Is it possible to disconnect the capacitor and start it manually until I find a replacement?
    3. measure the windings? will the capacitance of the capacitor not interfere?
    ELNA SZ 120/125 Bench Grinder: Hums, Turns Dial, Stops - Capacitor & Winding Issues, 230V, 4uF ELNA SZ 120/125 Bench Grinder: Hums, Turns Dial, Stops - Capacitor & Winding Issues, 230V, 4uF ELNA SZ 120/125 Bench Grinder: Hums, Turns Dial, Stops - Capacitor & Winding Issues, 230V, 4uF ELNA SZ 120/125 Bench Grinder: Hums, Turns Dial, Stops - Capacitor & Winding Issues, 230V, 4uF
  • #2 16479802
    stanislaw1954
    Help: 2013
    Rate: 4665
    1-probably yes, you just need to find out what broke.
    2-but for the engine to start moving, you would have to rotate it a lot, which is not really how to do it.
    3- measure the continuity of the windings (working and auxiliary) by disconnecting the capacitor.
  • #3 16479937
    e2rd.o
    Help: 39
    Rate: 111
    zlotowinfo wrote:
    And what now:
    link
  • #4 16479939
    zlotowinfo
    Help: 7
    Rate: 59
    I don't know if I measure well ...
  • #5 16480120
    stanislaw1954
    Help: 2013
    Rate: 4665
    The resistance of the windings only confirms that they are whole, not burnt, but who knows what values they should have.
  • #6 16480177
    ALIBABA I
    Help: 223
    Rate: 537
    kol. and your bearings did not fall there sometimes?
  • #7 16480187
    zlotowinfo
    Help: 7
    Rate: 59
    1. e2rd.o is too smart for me, and it is probably not profitable to give it to someone
    2.stanislaw1954 also do not know how much they should have, one thing that is not interesting is the cracked insulation of the capacitor wire, but it does not affect the start-up
    Father visited some specialist and got information that it was some kind of wire inside and bearings
    the cost of the repair is to be PLN 50.
    Which in my opinion is a bit much and I think I'll order some efficient stimulant on the Allegro.
    A familiar electronics technician denies the problem with the bearings, no friction, the dial will rotate several times after turning it by hand.
  • #8 16480199
    stanislaw1954
    Help: 2013
    Rate: 4665
    For PLN 50 it will definitely not "rewind" the windings, if it is a replacement of the capacitor.
  • #9 16480279
    zlotowinfo
    Help: 7
    Rate: 59
    I watched grinders on the Allegro for PLN 90 and I do not understand anything about it.
    Power 120W, 150W, 900W and 1700W.
    Up to such large spans of power? Are these parameters not correct? What to look for when buying?
  • #10 16480525
    stanislaw1954
    Help: 2013
    Rate: 4665
    Can you start with what do you need a grinder for? For sharpening a knife, broken screwdriver or for grinding coarse materials?
  • #11 16480688
    zlotowinfo
    Help: 7
    Rate: 59
    For the plot, scythe, knives and lawn mower knife.
  • #12 16480843
    e2rd.o
    Help: 39
    Rate: 111
    These powers will be real if you put the comma one place from the back.
    During the week I looked at CHAMPION Germany 1850W, I stopped behind the axle with my fingers, and the bearings are embedded in rubber seats and the rotor is blocked or rubbed against the stator.
  • #13 16481051
    zlotowinfo
    Help: 7
    Rate: 59
    My father was pissed that he could not do it and the new one was over PLN 100. He gave this guy what he would repair for PLN 50, he reassured his father that now they are doing this crap and better repair the old one (she has lived for 30 years).
  • #14 16481475
    nikusert
    Help: 699
    Rate: 1754
    Hello .
    In single-phase motors, and especially in these grinders (I repaired, or rather reworked) the problem is with the bearing seats. Large clearance in the seats causes that the rotor is not positioned axially in relation to the stator. We assume that the windings and the capacitor are in working order. other bearings, wider than the current ones.As I remember correctly, 6201 bearings are used, and 62201 should be used. These bearings are a bit wider, but fit, but you need to roll the rotor a bit in the places where they rest against the rotor when we put them on the shaft. You know why, because the spacing of the bearings changes and the covers will not go down to the stator.
    Best regards.
✨ The ELNA SZ 120/125 bench grinder exhibits issues where it hums, turns the dial slightly, and then stops when powered on. The user has measured resistance values of 27 ohms at 230V input and 57 ohms on the capacitor leads when disconnected. Insights from the forum suggest potential winding problems, with some users indicating that a faulty capacitor could allow the motor to start after being turned off. Suggestions for troubleshooting include measuring the continuity of the windings and checking for bearing issues. A repair quote of PLN 50 was mentioned, with discussions on the feasibility of manual starting without the capacitor and the importance of bearing alignment. The user also inquired about purchasing a new grinder, expressing confusion over varying power ratings.
