Water shut-off valve: which way to turn it off and how to deal with a jam?
emilpawlicki 57363 32
How do I turn off a water shut-off valve, which direction closes it, and what should I do if the valve is jammed?
Usually these valves close by turning clockwise (to the right), while opening is to the left [#20618359] If the knob will not move, remove the plastic cap/handle and its screw/nut, then try turning the spindle/pin directly with pliers or a wrench instead of forcing the knob [#20631891][#20632462][#20635197] If the spindle turns many full revolutions with no effect, the valve is likely internally damaged, so the practical fix is to shut off the supply near the meter first and repair or replace the valve [#20633439] For an old street/sidewalk main valve, the advice was to call the water company, because old gate valves often cannot seal properly and may disturb sediment in the line [#20618372][#20632462] Several replies also recommend replacing worn old-style valves with newer ones, and hiring a plumber if you are unsure about unscrewing the valve from the wall [#20634507][#20633439]
  • #31 20635033
    pawtys
    emarcus wrote:
    This valve is always open
    Can these shut-off valves be tightened, e.g. with a French wrench or, for example, with a tooth (grabbing the knob with something so as not to scratch it)?
    of course, it is about the moment of downtime when there is a need to close it
  • #32 20635197
    palmus
    Help: 232
    Rate: 745
    You can. But I don`t predict good luck. If you can`t do it with your hand, you will probably damage it with a tool.
  • #33 20635231
    pawtys
    palmus wrote:
    You can. But I don't predict good luck. If you can't do it with your hand, you will probably damage it with a tool.
    ok, I won't treat it as a tool
✨ The discussion revolves around the operation and troubleshooting of water shut-off valves. Users inquire about the correct direction to turn the valve to shut off the water, with general guidance indicating that valves are typically turned left to close and right to open. Several participants share experiences with jammed valves, suggesting methods such as using WD-40 to loosen stuck knobs and the importance of regular maintenance to prevent sediment buildup. Some users discuss the potential need for replacement if the valve is too old or damaged, and the challenges of accessing and repairing these components. The conversation also touches on the importance of hiring a plumber for complex repairs and the implications of flushing the plumbing system after valve replacement.
TL;DR: For 3–4 threads inside an old spindle valve, the rule is "right closes, left opens". This FAQ helps homeowners identify water shut-off valves, free stuck knobs, and decide when to replace jammed kitchen or street valves. [#20633439] Why it matters: A seized shut-off valve can fail during a repair, leak after movement, or leave the home without a reliable isolation point.
Valve type Closing movement Thread insight Main risk
Old spindle / mushroom-type valve Multiple clockwise turns Internal parts may be repairable Drips or stripped knob
Ball valve 90° lever turn Newer design mentioned as replacement Poor-quality unit may not seal
Street / sidewalk gate valve Clockwise to close Older than 10 years may not close tightly Sediment enters home installation
Key insight: If a valve will not close by hand, do not force it with a wrench as the first move. Remove the knob, inspect the spindle, and plan replacement before the old valve breaks.
  • Typical household water valves discussed in the thread follow the basic direction: turn left to open and right to close. [#20618359]
  • A street or sidewalk gate valve older than 10 years may not close tightly and may release sediment into the home installation. [#20632462]
  • Old-style spindle valves discussed here have a short internal thread, described as about 3–4 threads, not unlimited travel. [#20633439]
  • Newer ball-valve shut-offs close by rotating the spindle lever 90°, far less than multi-turn old valves. [#20633439]
  • Shut-off valves should be moved once every month or quarter to reduce scale and sediment seizure. [#20632462]
Which way should I turn a typical household water shut-off valve to close it?
Turn a typical household water shut-off valve to the right, clockwise, to close it. Turn it left, counter-clockwise, to open it. One forum expert summarized the rule as: "left opens, right closes." If the valve does not move by hand, stop before using more force. [#20618359]
What should I do when the main water shut-off valve will not move in either direction?
Do not force a main shut-off valve that will not move either way. First identify whether it is inside the house or in the street. If it is old, stuck, or shared, call the waterworks or a plumber. A street valve older than 10 years may not close tightly. [#20632462]
How can I identify whether a water shut-off valve is the house valve, a kitchen branch valve, or a street/sidewalk gate valve?
Identify the valve by its location and what it supplies. A kitchen branch valve sits under the sink and feeds one tap, dishwasher, or hot/cold line. A house valve isolates the whole home. A street or sidewalk gate valve sits outside near the service connection and may belong to the waterworks. [#20618372]
When should I call the waterworks instead of trying to close a street or sidewalk water valve myself?
Call the waterworks when the shut-off valve is in the street or sidewalk. That valve may isolate the wrong property or belong to the utility. One case described a double street valve where workers first shut the neighbor instead of the intended house. [#20618372]
How do I remove a stuck plastic knob from an old hot or cold water shut-off valve without damaging the valve?
Remove the visible screw first, then pull the plastic knob straight off if it is push-fit. Use a little WD-40 only around the knob, not as a seal repair. Check the screw hole and front of the knob while turning. If the knob still spins freely, cut the plastic rather than twist the spindle harder. [#20633322]
What does it mean when a shut-off valve knob turns many times but the water keeps flowing?
It indicates a stripped knob or internal valve damage. Old valves in the thread were described as having only 3–4 internal threads. If the spindle turns many full revolutions with no shut-off, the closing element is no longer moving correctly. Shut water upstream before disassembly. [#20633439]
How can I check whether the teeth or splines inside a plastic valve knob are stripped?
Remove the plastic cap and screw, then take off the knob and inspect its internal teeth. Also inspect the metal spindle shape beneath it. A working knob grips the spindle firmly. If the teeth are missing or rounded, buy a replacement knob before operating the valve again. [#20631891]
What is a gate valve in a water installation and how is it different from a small under-sink shut-off valve?
"Gate valve" is a water shut-off fitting that isolates a larger supply line, often at a street, sidewalk, or main connection, using a rising or lowering internal barrier. It differs from a small under-sink valve, which isolates one branch such as a kitchen tap or dishwasher. [#20618372]
What is a ball valve and why does it close with only a 90-degree turn?
"Ball valve" is a shut-off valve that uses a rotating internal ball to open or block flow, requiring only a quarter-turn movement. In the thread, newer ball valves were described as closing with a 90-degree rotation of the spindle lever. [#20633439]
Ball valve vs mushroom-type valve vs ceramic insert — which is better for household water shut-off points?
Use a quality modern replacement and exercise it regularly. The thread suggests ceramic inserts as expensive, mushroom-type inserts as an alternative, and ball valves as common newer designs. It also warns that neglected ball valves, especially cheap units, can seize from sediment. Move any type monthly or quarterly. [#20632462]
How can WD-40 help with a stuck valve knob, and what are the risks of using it around plumbing fittings?
WD-40 can help free a stuck plastic knob from the spindle area. Use it lightly and only as an aid for removing the knob. It does not repair a worn seal, broken internal thread, or leaking valve. After movement, the user reported drops appearing at the valve. [#20633346]
Why can an old valve start dripping after it is turned or disturbed for the first time in years?
An old valve can drip because movement disturbs scale, rust, or the spindle seal. The thread shows an edge case: after 10–15 clockwise turns, drops appeared while the valve piston moved. Once disturbed, a worn packing area may need repair or replacement. [#20632910]
What parts are usually inside an old spindle-type shut-off valve under the knob and packing nut?
An old spindle-type shut-off valve usually contains 3 main internal parts. These are the spindle with a rubber seal at the end, a rubber spindle seal, and a metal washer under that seal. Turn off water near the meter before opening this area. [#20633439]
How often should household shut-off valves be exercised so they do not seize from scale or sediment?
Exercise household shut-off valves once a month or once a quarter. The recommended routine is simple: 1. Turn the valve partly closed. 2. Turn it fully open again. 3. Confirm there is no drip around the spindle. Neglected valves quickly collect sediment and stop working. [#20632462]
What precautions should I take before replacing old kitchen hot and cold water shut-off valves with new ones?
Close the upstream water supply before replacing old kitchen hot and cold valves. Keep new valves ready, because an old pin may break or debris may block closure during movement. Replace both hot and cold valves together if both are old or unreliable. Hiring a plumber was judged the best idea. [#20634507]
