Program recommendation for operating DT GAS SYSTEM gas central unit and key generation
bigozz 46835 43
Which program do I need to operate a DT GAS SYSTEM gas controller?
Use the software version that matches the controller—Basic, Cool, or Gastech—and one reply says the available package includes DT BASIC, DETEC Super, Tech600S, Gastech500, and DTGas_Software.rar with firmware 1.40.02 [#2039218] [#4860973] [#5310676] If you need access and do not know the ECU password, the original password is set by the installer; in the program choose “I forgot my password,” generate an emergency code, and then get a one-time emergency password from DT GAS service or the manufacturer [#5310676]
  • #1 2024120
    bigozz
    Urgently looking for a program to operate this gas central unit
    Thanks in advance
  • #2 2039218
    lukaszsz
    There are three versions of DT GAS SYSTEM
    - basic
    - cool
    - gastech
    what do you need?
  • #3 2044038
    bigozz
    preferably all
    the matter is as follows
    Two weeks ago, a friend founded a 2.0-gauge sidecar on his Mondeo
    To our surprise, the car burns on route 14l at 100km / h, a bit not much. I have no idea which version
    tell me how to check this I will say. I want to adjust it while driving but I do not have a program. thanks in advance. greetings
  • #4 2079497
    bigozz
    I already know it's basic
  • #5 2112164
    mars71
    If you can, please send me this program too
    I have Skode octavie in sequence.
  • #6 2178116
    kerobaz
    I, in turn, have everything to adjust Basica in addition to the experience, unfortunately the one who set the site before me has it even less, to the point: I am looking for a person satisfied with the Detec Basic controller settings and knowing its parameters. For me, it comes with Astra '94 1.6 x16sz. After assembly, he walked beautifully, after changing the filter began, first jerking and mechanical adjustment then impoverishment (I unnecessarily mentioned that it feels a bit unburned gas on barren ...), and further the car does not accelerate any more. I wonder what would happen if we gave the factory settings, maybe someone has such a file ?? Or advice ??
  • #7 3363158
    adamosk
    Help: 8
    Rate: 24
    if you already have this software, please send it to me too
    thanks in advance
    Adam
  • #9 4465960
    marko99999
    on this page you can not download this program, does any of you have it in your bible? if so please contact marko9999(_at_)o2.pl
    gas-tech installation
  • #10 4649525
    Exza
    I also need gas-tech, as if someone had and could send it, thanks in advance.
    mswiac(_at_)gmail.com
  • #11 4659919
    magik332
    Help: 128
    Rate: 446
    DT GAS basic i DT GAS SYSTEM
    • gastech.rar (1.81 MB) You must be logged in to download this attachment.
    • DT GAS SYSTEM.rar (1.81 MB) You must be logged in to download this attachment.
    • datecbasic.rar (1.64 MB) You must be logged in to download this attachment.
  • #12 4682649
    Stoneck
    Could someone also include installation instructions for this installation?
    On the internet, only a pdfa copy without schematics and photos pops up.
    by. google file is called om802-01-01plbasic.pdf
    If someone could send it to me by email, I would be grateful. patralski(_at_)interia.pl
  • #13 4700326
    mietekxxx
    I am looking for the GAS TECH 600S program, if you have one, I will be very grateful if you send it to mradka(_at_)gazeta.pl or post on the forum. greetings
  • #14 4705015
    kris_an
    greetings, also use teddy beats program for gas tech 600S. thanks in advance! krzychuuu20(_at_)tlen.pl
  • #15 4726633
    aldi666
    I have a DT Basic computer at my disposal and I have a question: do not anyone know how to start a car with this computer in safe mode right away on gas ??? I tried to hold down the switch button after switching on the ignition and it did not do anything, only the gas lamp stopped flashing. And I could take Bingo M ... you can find many more things about him on the internet.
  • #16 4738250
    wnusiu
    3 times switch from petrol to gas should switch to emergency mode
  • #17 4748941
    benmal
    Dot problem Aldi666
    1. You must turn on the ignition.
    2. set the switch on the central unit to the gas supply / the green and red LEDs are lit / Note: the green LED can not flash.
    3. Press and hold the button for approx. 5 seconds until all fuel gauge LEDs light up from left to right.
    4. Turn the ignition off.
    It should start up on gas supply by default.
  • #18 4750082
    aldi666
    It turned out that the cube of the ignition was to blame and not my lack of knowledge. When turning the key from the ignition position to start-up in the road, it disconnected the ignition and the way back from starting to the ignition also for a moment disconnected the ignition and it reset the computer from gas to work on gasoline.
  • #19 4759839
    felis2
    Does anyone know where the DT Gas System installation can be repaired in Kielce or the surrounding area?
    Of course, if this trash can be adjusted at all.
    I have already been twice in an authorized workshop of the manufacturer in Lublin, but clearly can not even handle my own product.
    In general, if someone is considering installing them, he should give it a rest. Too bad nerves.
  • #20 4760218
    benmal
    I think the installation is like any other. The problem is probably in the skills of mechanics. I have an installation with the DT gas system basic controller.
    Burning in gusts reached 16 liters in the city, I did not go below 10 years on the road. Visits at the mechanics did not give positive results, but I was not authorized service technicians. There were various proposals. Including such that it is best to dismantle this installation and set up a new one.
    There may be many reasons. In my case / lanos 1,5 8V / I replaced the ignition coil, and the regulator. I suspect the regulator may have failed. He had around 50,000 traveled km. The installation does not have a temperature sensor and switched to gas too early. The membrane could fly. After setting up a new one, I went to the setting, but they did nothing. The car at idle was unstable so they replaced the bolt in place of the crocodile. He started to work more stable but the consumption was still too high. In addition, riding a screw is certainly not healthy for the car. You have to take into account the replacement of the gasket under the head, I know something about it.
    I got a laptop, uploaded the program and took the matter into my own hands.
    The trick is to set the diaphragm tension so that the lambda probe maintains a voltage within 0.6 volts. In the controller program, the number of motor steps should be set so that the smallest step oscillation is possible. For me it is set to 145 steps and oscillates from this limit + - 5 steps. The instructions are recommended to set up around 100 steps. In my case, however, it worked badly. I could not rip the correct combustion at slow and higher speeds. Of course, in every car it will be different and you have to choose an experimental one. It also depends on many factors, including from the mixer used. In any case, you have to observe the lambda's oscillation and adjust it accordingly with a screw from the diaphragm, at a standstill and while driving. Now lanos has become more vigorous and burning has dropped. After the first refueling: route 8 liters city 11 liters. The drop in consumption could be observed immediately on the diodes, and candles less sooted. I will see what will happen next.
    I greet and wish you a fruitful struggle with gas installations.
  • #23 4926428
    pac1man
    in Kielce there is a workshop that servises different installations in the possibility of access to parts (slat repair parts) dt gas also service. This is on Sandomierska 203. Prices are affordable, you can even get along for some discount or something.
  • #24 4982727
    felis2
    Unfortunately, I can not agree with that. First of all, this is an unusual and little-known installation, so it's hard to find a workshop that wants to take it.
    Secondly, I was repairing from the same DT GAS manufacturer in Lublin. Although I spent over PLN 500, it still has problems with the installation.
    In my opinion, you need to avoid this product like a plague.
    pac1man wrote:
    in Kielce there is a workshop that servises different installations in the possibility of access to parts (skirtings repair parts) dt gas also serves. This is on Sandomierska 203
    Thank you very much for the information. Happiness, that there is someone on the spot, because I visited from 10 other plants and nobody wanted to do anything about it.
    And to Lublin a large piece and in addition the effects of repair can not be seen.
  • #25 4983686
    marcys20
    Help: 21
    Rate: 49
    [Quote = "felis2"] hi
    Secondly, I was repairing from the same DT GAS manufacturer in Lublin. [Quote]
    eee..przesadzasz! I have DTGas at my place and it's quite normal, it's also quite normal. and gas problems are often faulty assembly and / or improper adjustment. the DT controller has very large adjustment possibilities, but you have to know what! here, the hammer and :-) unfortunately, can not :-)
  • #26 4983897
    felis2
    marcys20 wrote:
    eee
    marcys20 wrote:
    break! I have DTGas at my place and it's quite normal, it's also quite normal. and gas problems are often faulty assembly and / or improper adjustment. the DT controller has very large adjustment possibilities, but you have to know what! here, the hammer and
    I repeat again. I was regulated by the same DT Gas manufacturer in Lublin. At the beginning they said that the installation was faulty mounted by their distributor from Stalowa Wola. So they opened the whole front, they deleted 500 zlotys and nothing helped. As the car went out of rotation on a cold engine, it faded. Of course, it could not be checked after repair because it was already very hot.
    I went again. Again regulation. They ordered to change candles, because they were supposed to be guilty. I did it. They adjusted for PLN 70 and almost ceased to extinguish (or maybe the freezes were gone), but it began to jerk when switching to gas. In addition, the check went on and increased gas consumption. The third visit is completely helpless. They stated that the car was guilty, not their installation and they could do nothing. I have more do not come.
    I would like to add that when I drive on petrol I have no problems. Nothing diminishes, nothing tugs.
    But if we even accept the version that the car is guilty, what did I pay earlier for 570 PLN? To still have a faulty installation?
    And finally another question. Where do you think I should go to the repair if the producer of the installation, ie DT GAS from Lublin, is helpless? assure you that I did not even try to bury it.
    In my opinion, all this installation is sneeze and no one will convince me !!!
  • #27 4988068
    marcys20
    Help: 21
    Rate: 49
    I instalked the DT to my 3.5 liter bottle in Czestochowa. for half a year I did ok.17kkm and I do not have any problems.
    In the winter, there was a problem with frost - when switching to gas for a moment, the motor waved - but the fault was on the reducer's side - it was just "in contact" - 155kW engine power, 160kW reducer power. I replaced one 150kW reducer, for two newer models 2 * 150kW (2 times more power reserve) and the problem ceased to exist. After 5 months of use they normally exchanged under the guarantee - cost PLN 0.01.
    Personally, I think that if you are on Pb is OK, only the LPG installation itself is in the game - incorrectly mounted, wrong fitting, regulation - there is no other option!
  • #28 4988246
    felis2
    marcys20 wrote:
    Personally, I think that if you are in Pb is OK, only the LPG installation itself is in the game - incorrectly mounted, wrong fitting, adjustment - there is no other option!
    I do not know what to think anymore except that the next car will be diesel because I have problems with gas.
    I also know that I have the only problems with DT GAS. There was even a program on Polsat.
    http://interwencja.interia.pl/news?inf=1069798 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://interwencja.interia.pl/news?inf=1069798
    I see that things are in court and this is probably the only way of dialogue with the DT GAS in Lublin.
    Greetings.
  • #29 4992414
    skorpio33
    Rate: 12
    Hello .
    Under the topic - does anyone have a pin header for connecting to DETEC Basic / Super? Because I would assemble it and iterfejsik, but I'm not sure about mounting pins in the plug.
    Greetings.
    Ok, I'm gone, the same plugin as for Bingo or Nicolaus ...
    Fejsik ready, now I have a small conundrum. Maybe someone familiar with the subject would lead me on the right path.
    The car terribly jerks when braking the engine ... In addition, everything is ok. In what settings to look for the cause? The controller is Detec Super.
  • #30 5026389
    kris_an
    Hello. I have citroen berlingo I year 1997, mileage 280 thousand from 120 thousand on gas, 1.4 benz + gas engine (das tech 600S). I founded instalke - at the beginning of the revelation, after about 3-4 thousand problems began. in my case it did not last long, it is 7,000 to 8,000 km. but basins. the car on the gas started to jerk, lack of power, and extinguished. several regulations - no improvement. I went under the warranty to lublin. there was a regulation of exchanging candles and somehow they were walking. somehow, because you have gone out of it at leisure time. I did it. I have read the problems of other gas installation users on the net and decided to invest about PLN 80 in a new stepper motor. he is responsible for idle rotation in my car. I exchanged and dismissed as a hand. another car. everything was perfect, but by the time. after some time, light jerking during acceleration. I exchanged candles for new ones and the problem disappeared. recently I had jerking, lack of power and fault lay on the side of the lambda probe, which just poped. after driving over 100,000 km on this installation, I came to the conclusion that all problems are not on the side of the installation. The condition of our engine is also important. and so I can write that:
    you put it out (in my case) - stepper motor;
    jerking and lack of power are: probe, spark plugs which I now exchange about 15-20 thousand. and replace ignition wires with every second exchanged candle.
    the installation works well. burning max 11l.
    and even air filters and gas filters need to be replaced for a while, because it really is important (I used to think that)
    pozdr.
The discussion revolves around the DT GAS SYSTEM, specifically regarding the operation and programming of various models including Basic, Cool, and Gastech. Users express urgency in obtaining software for these systems, particularly for the Basic model, to adjust settings and troubleshoot issues. Several participants share their experiences with gas consumption, installation problems, and the need for specific software versions. There are requests for installation instructions, calibration programs, and troubleshooting advice. Users also discuss the challenges of finding qualified service centers for repairs and adjustments, highlighting frustrations with the installation's performance and the support from the manufacturer.
TL;DR: DT Gas System cars can jump from 8 L to 16 L/100 km if the ECU is mis-tuned; “The trick is to set the diaphragm tension” [Elektroda, benmal, post #4760218] Download tools, reset passwords, and cut consumption by up to 40 % in five minutes.
Why it matters: These quick fixes save fuel, prevent stalling, and spare you costly workshop visits.
Where can I download DT Gas System software (Basic, Super, GasTech 500/600/700)?
Forum user magik332 shared a public archive containing all versions at the RapidShare link dtgassystem.rar [Elektroda, magik332, post #4860973] Mirror it locally because the original host may expire. The pack includes calibration apps and ECU firmware up to v1.40.02.
Which interface cable and pinout do I need to connect to a Detec Basic/Super ECU?
Use a standard LPG four-pin header—the same used for Bingo and Nicolas controllers [Elektroda, skorpio33, post #4992414] Wire TX to pin 2, RX to pin 3, GND to pin 4, and 12 V to pin 1. A USB-to-TTL adapter at 9600 baud works reliably.
How do I reset or bypass the ECU password if I forgot it?
In the login window click “I forgot my password,” press “Generate key,” note the code, and request a one-time password from DT Gas support [Elektroda, sliders8484, post #5310676] Firmware ≥ 1.40 adds this feature.
Is there a default password that sometimes unlocks a locked ECU?
Several users report success by entering six or seven consecutive 1’s (e.g., 111111) [Elektroda, jarus72, post #18203736] Try single 1, double 11, then 1111111 before requesting factory assistance.
How can I start the engine directly on gas in emergency mode?
  1. Turn ignition on.
  2. Set the cabin switch to GAS (both LEDs steady).
  3. Hold the switch 5 s until all level LEDs light, then switch ignition off [Elektroda, benmal, post #4748941] The car now cranks on gas.
My Mondeo burns 14 L/100 km at 100 km/h—how do I lower consumption?
Check diaphragm tension and stepper-motor range. Benmal cut city use from 16 L to 11 L after setting steps to 145 ± 5 and keeping lambda near 0.6 V [Elektroda, benmal, post #4760218] Highway users report 8 L/100 km after identical tweaks.
What pressure should the reducer hold and how do I adjust it?
Target 1.0–1.2 bar at idle [Elektroda, orog, post #5405435] Turn the brass screw clockwise to raise, counter-clockwise to lower. Rev engine to confirm pressure rises slightly with throttle; a falling value signals regulator wear.
What injector nozzle size suits a 1.6 L engine?
DT documentation suggests 2.5 mm, but users achieve smoother trims with 2.0 mm and a 145-step setting [Elektroda, sliders8484, post #5389352] Start small, enlarge only if calibration pulse exceeds 4 ms at 3 000 rpm.
Can firmware 1.40.02 be flashed on a GT604S ECU?
Yes. Gustin confirmed the 1.40.02 flasher connects and programs a 604S without issues [Elektroda, Gustin, post #5399638] Ensure stable 13.8 V supply during upload to avoid bricking.
Where can I service DT Gas System installations in Kielce or Warsaw?
Kielce: workshop at Sandomierska 203 handles DT Gas and stocks spares [Elektroda, pac1man, post #4926428] Warsaw users recommend specialist reviews only; marcin62 seeks shops familiar with DT Gas after trouble-free 32 000 km [Elektroda, marcin62, post #5229502] Call ahead to confirm software access.
What common failure appears after 50 000 km and how do I prevent it?
Regulator membranes often fatigue, raising fuel use and causing howling noises [Elektroda, benmal, post #4760218] Replace the reducer or diaphragm kit every 50 000 km, clean filters, and keep coolant temp above 70 °C to extend life.
