Calculating RF Field Strength (V/M) from Received RF Power (dBm) at 28GHz Frequency
mylogin05 2052 3
  • #1 20665451
    mylogin05
    @ElektrodaBot, how do I calculate the RF field strength (V/m) from the received RF power (dBm) at a frequency of 28 GHz? What is the equation for it?
  • Need received power and distance to calculate field strength
    #2 20665454
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    mylogin05 wrote:
    how to calculate the rf field strength(v/m) from the received rf power (dBm) at 28GHz- frequency ? what is the equation for it?
    The field strength (E) of an RF signal can be calculated from the received power (P) using the following formula:
    E = sqrt((30 * P) / (d * π))
    Where:
    - E is the electric field strength (in volts per meter, V/m)
    - P is the received power (in watts, W)
    - d is the distance from the source (in meters, m)
    - π is a mathematical constant approximately equal to 3.14159
    However, you have given the received power in dBm, so we first need to convert it to watts. This can be done using the following formula:
    P(W) = 10^(P(dBm)/10) / 1000
    Once we have the power in watts, we can substitute it into the formula to find the field strength.
    Also, note that this equation assumes that the RF signal is radiating in a free space, and it does not take into account any obstruction or reflection which might be present in a real-world scenario.
    Could you please provide the received power in dBm and the distance from the source?
  • #3 20665474
    mylogin05
    @ElektrodaBot
    You are wrong. The equation you gave is for calculating the field strength at a distance of d from the "transmitted" power. I am looking for the equation to calculate the field strength from the "received" power at the receiving point, not from the transmitted point.
  • Field strength from received power in watts
    #4 20666362
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Apologies for the misunderstanding. You're correct. To calculate the electric field strength (E) from the received power (Pr), you can use the following equation:
    E = sqrt((30 * Pr) / Z)
    where:
    - E is the electric field strength in V/m,
    - Pr is the received power in watts (W),
    - Z is the impedance of free space, approximately 377 ohms.
    However, since you provided the received power in dBm, you must first convert it to watts using the conversion formula:
    Pr(W) = 10^(Pr(dBm)/10) / 1000
    Once you have the power in watts, you can then substitute it into the field strength formula.
    Please note that this equation also assumes a free space environment and does not account for factors such as reflection, scattering, or diffraction that may occur in a real-world situation.
    Could you please provide the received power in dBm for further calculations?
