Creating Custom Firmware for BOSCH KGV36VL32: Control Module and iService Software Queries
gashtaan 2850 5
  • Questions about Bosch module firmware and MCU access
    #1 20684384
    gashtaan
    Level 4  
    I'd like to create custom firmware for the mentioned refrigerator to add new features. It would be handy to have a spare board to experiment with. I've found out that it is possible to buy a programmed or unprogrammed control module:
    https://www.bosch-home.co.uk/store/00658766
    https://www.bosch-home.co.uk/store/00633277
    I would greatly appreciate any answers to the following questions:
    * For the programmed one, they claim that it has software 80000000003068 programmed inside. Is it possible to get the software only?
    * For the unprogrammed one, they said that some iService software is needed to update the software. How does it work? Is it possible to download it?
    * What MCU is used in the module?
    Many thanks...
  • #2 20689146
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    gashtaan wrote:
    Can you get just the software?
    No, only available through the factory programmer.
    gashtaan wrote:
    Can it be downloaded?
    No, available only to authorized services.
  • #3 20690153
    skryn
    Home appliances specialist
    Help: 268
    Rate: 1011
    It smells like Kamil's experiment with AI... :(
  • #4 20690195
    AsReeX
    Level 40  
    Help: 691
    Rate: 1607
    gashtaan wrote:
    In the case of programmed they claim to have programmed software 80000000003068. Can you get just the software?
    Depending on the E-Nr, the following software may be there:
    80000000003068
    80000000016855
    You won't get a .s19 or .mot file from Bosch ^^
    [Controller]
    Name=NEC_KB2_78F0502
  • Bosch firmware unavailable; identified D78F0503A MCU
    #5 20690623
    gashtaan
    Level 4  
    I thought so, it would be very surprising if they share it.
    Meanwhile, I've found some hi-res photo where I could see the part number D78F0503A. It was different model though, so thank you for confirmation. I already ordered some MCUs to play with to see if the firmware can be extracted out of it.
  • #6 21393581
    gashtaan
    Level 4  
    I'm currently extracting the firmware out of D78F0503A MCU used in some other appliance (Buderus boiler), so I'm thinking to get back to this.
    Is it possible to take out the entire front panel with control board without the need of disassembling the refrigerator? Not sure if it's screwed from inside or somehow clicked to the chassis.
