Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module
Van_Gandalf 10770 17
Where can I get a compatible control module for a Bosch SPS53E02EU/01 dishwasher, and do I need to program it after replacement?
For the Bosch SPS53E02EU/01 with FD 9201 00859, a compatible control module was identified as part 00655467, but the exact variant matters because there are many versions of this dishwasher [#16295704][#16295884][#16296238] A similar dishwasher service manual and programming guide were recommended, because the replacement module may need adjustment or programming after installation [#16318188] The thread also notes that if the CPU is still alive, the burned SMD parts may be identifiable and repairable rather than replacing the whole board [#16318188][#16324064] One specific damaged board part was identified later as D13003 / STD13003, a 700V NPN transistor used for rinse-aid control [#17994291]
  • #1 16295574
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    I lost the control module in the Bosch SPS 53E02EU dishwasher. After applying voltage to the 78M05 stabilizer, the front panel is activated and the error E01 is displayed. There are some SMD components burned on the board and it is impossible to identify them. I am looking for module 9000 683 387.
    Moderated By skryn:
    I corrected the title of the topic.
    • Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module 20170221_103147.jpg (1005.84 KB) You must be logged in to download this attachment.
    mrhari
    Help: 836
    Rate: 3241
    There are 16 varieties of your dishwasher and not all of them have the same module.
    There are two numbers after the letters EU /. What?
  • #3 16295884
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    Sps53e02eu / 01
    Fd 9201
    00859
  • #5 16297516
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    The price killed ...
  • #6 16313033
    zielinskii
    Help: 20
    Rate: 112
    Better to buy used.
  • #7 16313340
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    I've already called half of Poland, unfortunately no one is there.
  • #8 16317978
    zielinskii
    Help: 20
    Rate: 112
    I have a few of these, but a maximum of 1 program is checked in them to see if everything works.
    Pawel1812
    Help: 44
    Rate: 267
    I invite you to read the service of a similar dishwasher and the module programming manual: https://www.elektroda.pl/rtvforum/topic3223298.html
    There may be a little trouble adjusting the stimulant module ... Unless the CPU survives.
  • #10 16323781
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    Buddy Zielinski, do you have a module for sale? In mine, several pieces are charred and I don't know the value. The processor turns on the drain pump relay and then displays E01. So there is hope that he has survived and the ports are not slaughtered. The service is also very helpful.
  • #11 16324064
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    Van_Gandalf wrote:
    There are several SMD components burned on the board and it is impossible to identify them
    Select carefully where and what these elements are, you may be able to help, as long as the processor is operational :D
  • #12 16330890
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    The processor may be good.
    • Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module 20170308_085640[1].jpg (4.86 MB) You must be logged in to download this attachment.
    • Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module 20170308_084141[1].jpg (3.55 MB) You must be logged in to download this attachment.
    • Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module 20170308_084108[1].jpg (4.15 MB) You must be logged in to download this attachment.
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module Bosch SPS53e02eu / 01 dishwasher - I'm looking for a driver module
  • #14 16335578
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    The path near the blue capacitor is already recreated with the green kynar.
    Can't identify the triac D1300 element ??
  • #15 16335682
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    I don't have a CD to read well, but can it read like this D13003 (D2-PAK)?
  • #16 16335745
    Van_Gandalf
    Level 19  
    Help: 7
    Rate: 43
    Initially, I assumed one, but controlling it is the "right" leg
  • #17 16396384
    ankel_345
    I have a dishwasher with a damaged heater.
  • #18 17994291
    Tomasz365
    Rate: 19
    The D13003 (D2-PAK) element is a 700V / 1.5 (3) A / 20W NPN transistor, designated STD13003. This is the rinse aid control.
The discussion revolves around the Bosch SPS53E02EU dishwasher, specifically the search for a replacement control module (9000 683 387) after the original was lost. The user reports an E01 error after applying voltage to the stabilizer, indicating potential damage to SMD components on the board. Various responses suggest that there are multiple variants of the dishwasher, complicating the search for the correct module. Some users recommend purchasing a used module, while others discuss the possibility of repairing the damaged components, including identifying a triac (D13003) and assessing the condition of the processor. Links to resources and manuals for similar dishwashers are also shared.
