Available Development Boards for OpenBeken Firmware Supported Chips BK7231T, BK7231N
rudolfbyker 1281 3
  • #1 20745471
    rudolfbyker
    Level 4  
    I have been successfully using OpenBK7231T on a few devices, and it works so well that I'm considering building new electronics projects with it, where I don't have to write any firmware myself! So, are there development boards available on the market for any of these chips?
    - BK7231T: WB3S, WB2S, WB2L, etc.
    - BK7231N: CB2S, CB3S, etc.
    - Or any other chip that supports the OpenBeken firmware.
    Rate: 12960
    You can use NodeMCU with swapped module:
    You can also use W600/W601 (even powersave works, but it has little flash memory):
  • #3 20748785
    rudolfbyker
    Level 4  
    Thanks! Those are good suggestions.
    Rate: 12960
    There is also a proto board without a module so you don't have to solder:
    Prototype board with ESP-12 and ESP32 markings.
