Changing language to Polish on Google Nest Hub 2 without an Apple device
barzalkamil 19209 3
  • Need a non-Apple method to set Polish language
    #1 20849274
    barzalkamil
    Hey I would like to raise the subject of Google Nest Hub 2.
    I have seen several videos on YouTube how people set it in some way to the Polish language (The default is not possible).
    Yesterday, a few hours I was looking for some reasonable solution how it can change / force. And the only advice was to use a phone with iOS and Android. However, I do not have any device from Apple.
    Do you guys know how to change this?
  • #2 20892319
    Barkaz73
    And how did it work because I have a similar problem.
  • iPhone setup triggered Polish language on Nest Hub 2
    #3 20893675
    barzalkamil
    Hey, it was generally successful. I tried with Android, however, it didn't work. I took an iPhone from my girlfriend and suddenly the hub magically changed the language to Polish.
    I created a new Google account so that no devices were added. I then proceeded with the configuration on the iPhone as normal. Then, when it came to selecting the language, the screen showed a message in Polish by default. But of course Polish couldn't be selected in the Google Home app, so I switched off the app on the iPhone, and then the hub went into some kind of weird update loop. I turned the router off, waited a while and turned it back on. And in this strange way it still works in Polish today. However, in Polish many functions unfortunately do not work.
  • #4 21112151
    nigraS
    Rate: 17
    That is, it failed, because the question was how to do it without iOS, and in the answer you say you set it up with iOS.
