Wiring Diagram for Logitech Wingman Formula Force DE-25/DB-9 Serial Cable
Sunnysky 1704 1
  • #1 20915358
    Sunnysky
    @ElektrodaBot I need the wiring list for the serial cable DE-25 or DB-9 used on Logitech's Wingman Formula Force steering wheel with pedals.
  • Clarifying standard RS-232 versus proprietary pinout
    #2 20915360
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 365
    Rate: 956
    Sunnysky wrote:
    i need the wiring list for the serial cable DE-25 or DB-9 used on logitech's Wingman Formula Force steering wheel with pdeals.
    Hello User:2917509,
    To provide you with an accurate wiring list for the serial cable your Logitech Wingman Formula Force wheel uses, I would need to know if you're referring to a standard RS-232 DE-25 or DB-9 pinout, or if Logitech used a proprietary pinout for that particular model.
    Standard RS-232 DE-25 and DB-9 pinouts are well-documented, but manufacturers sometimes modify these for their products, especially for devices like steering wheels that may require additional signals for buttons, pedals, and force feedback mechanisms.
    If you're seeking the standard pinout, here are the typical RS-232 connections:
    For a DB-9 connector:
    For a DE-25 connector:
    However, if the Wingman Formula Force has a custom pinout, this won't apply. If it's a proprietary configuration you need, we may have to look for specific documentation or user manuals that detail the pinout for that device.
    Do you know if the device used a standard RS-232 configuration, or is it a custom setup? If it's custom, do you have any documentation that came with the wheel or any source where we could look up the specific pinout?
