Landirenzo LC-01 Cable Wiring Diagram Needed for Blue Software Integration
xalexas 11052 3
  • #1 11414757
    xalexas
    I need cable wiring diagram for Landirenzo Blue software for LC01 unit. If someone has this diagram please post here.
  • #3 11419131
    xalexas
    Thanks, I have seen that post. If I have understood this post correctly I need USB cable with FTDI chip? I have tried cable (made from Nokia CA-35 cable) without FTDI chip and it won't detect ECU.
    I can't find anywhere wiring diagram for LC-01 diagnostic cable so tried combination RX TX GND and TX RX GND (didn't connect nothing to 12v socket)
  • #4 11480890
    xalexas
    I have successfully made cable for diagnostic. Unfortunately my LC01 is broken. I want to replace it with LCS-V05E. Since cable connector is not same I need to re-wire connector.
    Can someone be so kind help me to figure out those wires with question marks? Here is the photo of LC01 connector:
    Landirenzo LC-01 Cable Wiring Diagram Needed for Blue Software Integration Landirenzo LC-01 Cable Wiring Diagram Needed for Blue Software Integration
    Thanks.
