Dlaczego Nie Nazywamy Fazy i Neutralnego Plus i Minus w Prądzie Zmiennym?
geberit333 3327 9
Why can’t the phase and neutral conductors in a 230 V AC socket be called plus and minus?
They should not be called plus and minus because AC polarity reverses every half-cycle: the conductor that is positive relative to the other becomes negative, and vice versa. [#20918752] AC devices generally do not depend on a fixed input polarity; electronic equipment commonly rectifies the input with a bridge rectifier, while single-phase motors’ rotation direction is determined by their construction. [#20918824] The meaningful distinction is instead that the phase conductor has a varying voltage relative to earth, whereas the neutral is intended to be at approximately earth potential, so plus/minus terminology would be misleading. [#20918824] There is also no universal legal requirement that the phase be on the left side of a socket, although wiring all sockets consistently is good practice. [#20918684][#20918779]
  • #1 20918141
    geberit333
    Witam,
    Czemu na prąd przemienny nie można mówić plus i minus? Wiadomo, to nie jest prąd stały, ale w czym problem, żeby mówić, że z lewej strony mamy fazę, to jest plus, a neutralny to minus niebieski.
    No fixed phase side in sockets
    #2 20918684
    ArturAVS
    Moderator
    Help: 2304
    Rate: 7864
    geberit333 wrote:
    Why can`t we say plus and minus for alternating current?
    Because in alternating current the polarity changes depending on the frequency of the power supply network.
    geberit333 wrote:
    but what`s the problem with saying that on the left side we have a phase, this is a plus, and neutral is a minus blue.
    Read above, apart from that, there is no legal act specifying which side of the socket should be phase and which side should be neutral.
  • #3 20918752
    balonika3
    Help: 1338
    Rate: 3765
    geberit333 wrote:
    what`s the problem with saying that on the left side we have a phase, that is plus, and neutral is minus blue.
    Because that`s not the case. We have a plus on the left and a minus on the right. But after a split second there is a minus on the left and a plus on the right. And so on. I hope you`re asking seriously.
  • #4 20918770
    drunek
    Help: 86
    Rate: 219
    The phase is assumed to be on the left. But I'm just letting you know, let's not get into too much discussion about it, because it always causes a lot of emotions ;)
  • #5 20918779
    ArturAVS
    Moderator
    Help: 2304
    Rate: 7864
    No, buddy, nothing is accepted. There`s no point. However, it is important that all sockets within one building/flat/apartment are connected in the same way. This is simply good practice and does not in any way affect the operation of connected devices (some are specific, e.g. gas boilers).
  • #6 20918817
    Macosmail
    Help: 227
    Rate: 863
    In vertical double sockets, the phase and neutral are naturally reversed. In practice, it does not matter because all devices must be designed in such a way that it does not make a difference.
    Why phase and neutral are not plus and minus
    #7 20918824
    Xantix
    Help: 686
    Rate: 1658
    geberit333 wrote:
    Obviously, it is not direct current, but what`s the problem with saying that on the left side we have the phase, which is plus, and the neutral is minus blue.
    This is not assumed because for AC devices the polarity of the applied voltage is irrelevant to the polarity of the supply voltage. All electronic devices powered by 230 VAC have a power supply inside, the first part of which is a rectifier bridge that converts alternating voltage into direct current - so regardless of the polarity of the input voltage, the bridge will convert it into a voltage with constant polarity. In turn, for single-phase AC motors (both induction and series), the polarity of the voltage does not matter, because their direction of rotation is predetermined by the internal structure of the motor and, as such, independent of the polarity of the supply voltage.
    In such a situation, using a naming convention such as for direct current makes no practical sense. In single-phase AC networks, we are more interested in the potential of the wires relative to earth than to each other. Hence the terms "phase wire" and "neutral wire" are used - the phase wire is always at some potential relative to the reference earth, while the neutral wire always has a potential equal to the ground potential (i.e. its potential relative to the ground is equal to 0 V - hence the name "neutral". "). Therefore, adopting the terms plus and minus known from direct current would be very misleading here.
  • Phase and neutral reversal in vertical double sockets
    #8 20918845
  • #9 20919272
    geberit333
    Thank you very much for clarification and explanation on this topic! <3
  • #10 20919335
    geberit333
    >>20918752
    I was asking this question seriously because electricians recently attacked me when I said something like that. Someone simply misled me.
    Added after 30 [seconds]:
    >>20918824
    Thank you all very much for your clarifications. I really appreciate it! Regards
W dyskusji poruszono kwestię, dlaczego w prądzie zmiennym nie używa się terminów "plus" i "minus". Uczestnicy wskazali, że w prądzie zmiennym polaryzacja zmienia się w zależności od częstotliwości, co sprawia, że przypisanie stałych wartości "plus" i "minus" jest niepraktyczne. Zamiast tego, używa się terminów "przewód fazowy" i "przewód neutralny", które są bardziej odpowiednie dla systemów AC. Wskazano również na znaczenie jednolitego podłączenia gniazdek w budynkach oraz na dostępność gniazdek z funkcją niezamienności faz.
