How to Update Firmware on Grundig 49 VLE 6621 WP via USB - Double Blue Flash Issue
spantor 4839 3
  • #1 20983231
    spantor
    Mark:Grundig
    Model:49 vle 6621 wp
    Chassis (main board, components): Chasis G7. Mb ZG7190R-7
    LCD Screen/Panel (if exist):
    More informations:
    Double blue flash in LED stand-by and off
    I need firmware to install via USB.
    thanks in advance
  • #2 20984451
    billobirillo
    Help: 338
    Rate: 798
    latest software V11.009.00
    copy the folder Target_G7 on an empty usb stick
    tv disconnected from ac mains, plug the usb stick
    while holding down the joystick (or the power button) on the tv, plug the power cord
    and continue to hold down until the recovery process starts
    • G7_V11.009.00.rar (131.25 MB) You must be logged in to download this attachment.
  • #3 20984812
    spantor
    Thank you so much. I will try and report
    Added after 5 [minutes]:
    >>20984451
    I imagine usb with fat 32. or Not?
  • #4 20985904
    spantor
    Unfortunately it hasn't worked. The TV is unable to start the installation. I must have some hardware problem.
    Thank you anyway
