Mercury Innovations Bulbs Flashed with Tuya Cloudcutter Show as Sensors in Homeassistant
ricricpereira 1212 2
  • #1 21022678
    ricricpereira
    I recently flashed a couple Mercury Innovations bulbs with Tuya cloudcutter but unfortunately the domains are only showing in Home Assistant as sensor entities. How do I fix this?
  • #2 21022810
    Rate: 12954
    Did you configure the bulb? Is it working when used from HTTP panel?
    Can you do a config extraction:
    Remember to do HASS pairing after configuring your device (not before):
  • #3 21027373
    ricricpereira
    I got them working. Thanks
