Flashing Home Awesome EBE-BAW577-F Bulbs with Tuya Firmware 1.3.20
yonubear 1206 4
  • Cloudcutter fails to identify flashing pins
    #1 21349995
    yonubear
    Level 4  
    identifying and flashing bulbs
    I am on to my next project I can't get these to flash via cloudcutter even though the tuya firmware is 1.3.20 it even gets the keys from the firmware and I can't seem to identify the pins
    the bulb is labeled
    home awesome
    ebe-baw577-f 120v 14W
    reb cct e26 1400lm
    LED circuit board with arranged diodes and components held in hand. Close-up of a Home Awesome bulb with technical markings. Interior of a light bulb with visible PCB and markings.
  • #2 21351191
    Rate: 12880
    So you haven't flashed it with OBK yet? I guess A1 and B1 are UART1?
    It's the same module as here Nous Smart WiFi Bulb P8 RGBCW, GU10, EB01-B + BP5758, pinout WiFi
  • #3 21353015
    yonubear
    Level 4  
    no i have not flashed it yet I was trying first to get one to work via OTA flash before dismantling as I have roughly 25 of these all through the house
  • Cloudcutter workaround for Tuya 1.3.20 bulbs
    #4 21354003
    yonubear
    Level 4  
    ok i got it working thanks to the folks over at the cloudcutter github there was no profile for 1.3.20 it flashed to open bekten an seemed to work fine on the template for the nos gu10 here is the json if it helps anyone
    "vendor": "Tuya",
    "bDetailed": "0",
    "name": "Full Device Name Here",
    "model": "enter short model name here",
    "chip": "BK7231N",
    "board": "TODO",
    "flags": "5120",
    "keywords": [
    "TODO",
    "TODO",
    "TODO"
    "pins": {
    "24": "BP5758D_DAT;0",
    "26": "BP5758D_CLK;0"
    "command": "",
