Can the TJA1050 and SN65HVD230 work together on the same CAN network?
Primo83 1047 0
  • Comparing TJA1050 and SN65HVD230 for one CAN bus
    #1 21257903
    Primo83
    CAN home network (smart home).
    I have two questions :) .
    1. can I plug devices based on TJA1050 and SN65HVD230 into one network? (the boards have different power supplies and I don't know if this affects the H and L lines, and if so, I don't know if it matters)
    2. i want to create some custom circuits based on esp (using esphome) and i don't know which transceiver is generally better for smart home applications. I would be grateful for a hint.
    P.S..
    I'm still thinking about modbus, but there is a master/slave circuit there and I don't know how I would interface this with the :) switches, i.e. how is the slave supposed to let the master know that it has changed state etc.?
    https://esphome.io/components/canbus/esp32_can
