Aerocool Power Supplies: General Opinion, Quality, Pricing, and User Experiences
swiercm 37548 24
Are Aerocool power supplies generally good quality, and are they worth buying despite mixed opinions and a poor blacklist placement?
Aerocool power supplies are generally viewed as average, usable units rather than top-tier models: the VP-450 is fine mainly for office PCs or lighter graphics, while stronger gaming builds should use something with a better +12V rail [#11922598][#11938600] Some users report very positive experience with the Strike-X 600W and VP-450, including quiet operation, stable voltages, good protections, and no problems even after OCCT or overclocking [#11922196][#11922446][#11938570] For the VP-450 specifically, there are at least two versions: an older Andyson-made model with 336W on +12V and a newer 312W one; the older version is described as quiet and able to shut down correctly on a short circuit [#11925156] The main criticism is value for money: around PLN 130 for roughly 312/336W on +12V is seen as weak compared with alternatives such as Fortron or CoreXStream [#11938600] Overall, the thread suggests Aerocool should not be treated as outright bad, but also not as a clearly recommended brand [#11938001][#11939611]
  • #1 11922142
    swiercm
    Moderator on vacation ...
    Help: 1216
    Rate: 552
    I spend some time on the electrode, a lot of advice was given on the use of different power supplies.
    I am interested in the general opinion of the Aerocool brand.
    On the standard list of Elektrody.pl concerning the "Black and White list of power supplies" Aerocool is in the first place (alphabetically) of power supplies not recommended.
    https://www.elektroda.pl/rtvforum/topic1199271.html
    I have not heard a bad word in terms of the operation of their power supplies (maybe only that they are of average quality and too expensive - but if someone gets a gift?).
    Maybe someone has experience or is able to clearly determine whether these power supplies are good or not.
    Regards.
  • #2 11922196
    brysiu28
    As a user of the aerocool strike-x 600w, I can see only positive things. Certificate, a lot of security, effective 14cm fan, quiet, you can't hear it. I tested the meter recently and the voltage is very good, besides a lot of outputs and there will be no problem with handling the latest graphics cards. 0 problems so far.
  • #3 11922218
    swiercm
    Help: 1216
    Rate: 552
    How much time do you use it? It is also important. It is also important whether the configuration was subject to OC and how the Power Supply behaved.
    You see, my power supply is soooo years old, it has passed many times, and the voltage is still there, like on the first day I bought it.
    12.20V to + 12V
    5.19V to + 5V
    3.44V to + 3.3V
    I did not measure the rest - + 5VSB, I did not have a chance, but I think it is normal.
    Once I accidentally made a short circuit on the mini molex contact and the sparks just went and it turned off immediately.
    This is also what I mean to state the behavior of the power supply in extreme situations. Of course, if someone had such "adventures", because it is pointless to test the only computer in the house just to share such information.
    Added after 4 [minutes]:
    Dear Moderator - but I do not want to buy it, and this is a typical hardware topic, so I do not understand why it landed in the what to buy section. But let it be.
  • #4 11922281
    okokpopo1
    Help: 30
    Rate: 26
    The Aerocool is good: d Low prices and powerful power supplies.
  • #5 11922288
    finerek123
    Have you had contact with the VP-450? Time to catch up :D
  • #6 11922303
    swiercm
    Help: 1216
    Rate: 552
    I just didn't have, and I get a lot of questions, is it good equipment or not, and I don't know what to answer. I have no conviction, but maybe I'll change my mind.
  • #7 11922318
    finerek123
    This is the minimum when it comes to branded power supplies. Just in time for the office.
  • #8 11922329
    swiercm
    Help: 1216
    Rate: 552
    The best dell'e or hp or laptops from decent companies are the best for the office. It is This power supply is good or not good. Easy question.
    Put it closer to the feelings or closer to the fortrons?
    And donate, but I would not pay PLN 130 for a power supply, which I cannot rely on for the branded one at the same price.
    Hence this topic.
  • #9 11922342
    finerek123
    It's hard to comment on this. A bit better than the Feel III.
    But he is a bit short of the fortress. Despite the price.
  • #10 11922363
    finerek123
    However, in my opinion, it deserves to be on the list of reputable brands. Which, moreover, can also be enriched with SilentiumPC.
  • #11 11922388
    Gancus
    Speaking of updates, it would be useful to refresh the topic with recommended sets.
  • #12 11922395
    swiercm
    Help: 1216
    Rate: 552
    The set, the set is right - but there is plenty of it! And the companies producing Power supplies now and available on the market are maybe 30 in total (I do not count fakes, etc.) Only those that "walk" sell.
  • #13 11922446
    brysiu28
    I have it 2 years old, my amd phenom ii 965 be was turned up to 3.8 ghz. Tested for an hour of occt, everything is nice and stable, the voltage is great, the temperature is ok. In the near future, after changing the cooling on the card, I will overclock the GPU.
  • #14 11922456
    swiercm
    Help: 1216
    Rate: 552
    So so far everything points to the whitelist. We'll wait yet. Thanks so far.
  • #15 11922598
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    I put together a few sets on the VP-450 myself. Considering that it has just over 300W at 12V - this result is not knocking you on your knees. In my opinion, it is perfect for office configurations or with light graphics (let's assume that for a platform with S1155 + HD7770 or a comparable platform that can drain from 12V around 200W with a load, I would not be afraid to use it).
    The power supply itself has a reasonable quality of workmanship, not the shortest cables, it is not bothersome noisy, the set with G860 + hd7770 did not let go of the smoke during the hourly "power supply" test, the voltage measurement with a multimeter did not indicate any problems. I do not remember exactly what the wiring was for, for office sets or for the mentioned g860 it was just right.
    In my opinion, a solid medium, but due to the rather average performance at 12V, it is suitable for sets with integrated or lighter graphics. In the set for the player, I would opt for something with a better 12V line.
    I will not hesitate to buy this power supply again when I build a lighter set.
  • #16 11925156
    p1024
    I have been using Aerocool Vp-450 for nearly two years and in fact it is ok. However, for some time there are two versions on the market called Aerocool vp-450, the earlier one produced by Andyson with a power on the + 12V = 336W line and another version with a power of 312W. Below are links to both, with photos of the nameplate:
    1.http: //archiwumallegro.pl/zasilacz_aerocool_vp450_450w_bardzo_cichy_24h-1771637082.html
    2.http: //pcshop33.ru/price/hardware/p_c_2:t_107:s_2:info_105710_BP_450Vt_Aerocool_VP_450_ATX12V_V2.3.html
    So when it comes to Andyson, I have a good opinion about this power supply. It is quiet at rest, after a long period of use, the fan does not rattle, you cannot hear the coils. He survived a short circuit on the board, the board died, but the protection was on time and turned off the power supply before damage. It is used with Vtx HD4850 DDR5 (OC @ 625MHz + G630). Voltage stability average, but nothing more than ATX standard quite typical in this price segment. Fluctuations on the + 12V line were in the 12.05V -12.25V fork, between the iddle and the full load of the power supply in the OCCT.
    However, it is difficult for me to say something about the weaker version (312W), because it is probably a completely different platform. For today, at a low price, I would recommend the Chieftec GPA on a nice CWT platform, although it has slightly shorter cables.
  • #17 11927069
    swiercm
    Help: 1216
    Rate: 552
    The GPA chieftec is a power supply that is increasingly being heard about unfavorable opinions. I think unfortunately they saved on the project.
    At one time, opinions about my power supply were also divided, so maybe time will show how it really will be.
    So we already know that Aerocool is also a product in the product and that is what it is all about.
  • #18 11938001
    brysiu28
    And thanks to this theme, aerocool has disappeared from the blacklist! :D
  • #19 11938498
    finerek123
    Only it was not on the list of good power supplies.
  • #20 11938570
    zieloczek100
    Help: 58
    Rate: 51
    A colleague has the Aerocool VP-450 since November with the HD6850 + G860 and so far it has been working well ;)
  • #21 11938600
    Kasek21
    Help: 4981
    Rate: 3548
    Anyway, the average power supply - 312 / 336W for 12V for PLN 130 is nothing. Fortron for PLN 49 has 300W.
    The only advantage compared to, for example, HLN is longer cables and a longer warranty.
    For PLN 150 there is a CoreXStream from 444W to 12V.
    It's hard to qualify power supplies only by brand, because manufacturers have more and less successful power supplies - the fact that it is on the "white" list does not make it a good choice, for example, looking at the confrontation with the CXS.
  • #22 11939611
    swiercm
    Help: 1216
    Rate: 552
    But there is already progress, and life and time will verify whether it gets on the list of recommended brands.
    Thanks to this, I think that now there will be a few more purchases with his participation, and thus, there will be a larger test field and then it will turn out what equipment it is.
    As I wrote at the beginning - I know that it is not great in terms of price, but if someone gets it, they will not think about replacing it immediately, and that was it.
    BTW, I hope that in the thicket of products, despite the low power, it will prove itself and how is it really with them - we will see if it holds its power stiffly, or if it has less power, or maybe it is possible to squeeze more out of it than the factory predicted.
    I leave the topic open - if someone meets with Aerocool , he will have the opportunity to test it a bit, let him write his observations, results etc. Of course with markings.
    Thanks for the posts so far, ladies and gentlemen.
  • #23 11997388
    helmud7543
    Help: 1216
    Rate: 1564
    For me, 450 work in my office computer. It is not sawn when it comes to power consumption, but ...
    The power supply was replaced because the previous computer was unstable, lost USB devices or did not detect them. After replacing everything is ok, no matter how many and which USB devices I would not use. And it's really quiet.
  • #24 12197139
    TooMeeK
    Help: 39
    Rate: 39
    user AEROCOOL STRIKE-X 600 From this side.
    No problems for several months, power-hungry graphics, several disks, an additional CPU core unlocked from time to time.
  • #25 12375587
    helmud7543
    Help: 1216
    Rate: 1564
    There is the first fault - the fan starts to growl, especially at idle ...
The discussion centers around the Aerocool brand of power supplies, particularly the VP-450 and Strike-X 600W models. Users express mixed opinions, with some reporting positive experiences regarding performance, stability, and noise levels, while others highlight concerns about quality and pricing. The VP-450 is noted for its suitability in office configurations and light gaming setups, with some users mentioning its adequate voltage stability and quiet operation. However, there are warnings about variations in quality between different production batches. Overall, while Aerocool power supplies have received some favorable reviews, they remain a topic of debate regarding their reliability and value compared to competitors.
TL;DR: Aerocool VP-450 outputs 312–336 W on 12 V rail; “a solid medium” noted dt1 [Elektroda, 11922598] Most forum tests show stable voltages, quiet operation, and working protections, though one fan failure appeared after months [Elektroda, 12375587] Price hovers near PLN 130 [Elektroda, post #11938600]
Why it matters: Shoppers can judge if an Aerocool supply fits office or light-gaming builds without overpaying.
• 12 V capacity: 312 W (newer) or 336 W (older) VP-450 revisions [Elektroda, p1024, post #11925156] • Street price: PLN 110–140 for VP-450 in 2013 listings [Elektroda, Kasek21, post #11938600] • Warranty: 3 years stated for Strike-X series “Aerocool Global Warranty”. • Typical load tested: G860 + HD7770 ≈ 200 W from 12 V [Elektroda, dt1, post #11922598] • First reported fault: fan growl after ~7 months on VP-450 [Elektroda, helmud7543, post #12375587]
Is the Aerocool VP-450 reliable for an office PC?
Yes. Multiple users ran VP-450 for one to two years with no shutdowns or voltage issues in office systems [Elektroda, p1024, #11925156; helmud7543, #11997388]. A technician called it “perfect for office configurations” [Elektroda, dt1, post #11922598]
How much power does the VP-450 really deliver on the 12 V rail?
Two retail versions exist: 336 W (Andyson platform) and 312 W (second revision) as shown on their labels [Elektroda, p1024, post #11925156]
Can the VP-450 handle a mid-range gaming card like the HD7770 or HD6850?
Yes for single-GPU setups drawing ≤200 W from 12 V. dt1 stress-tested G860 + HD7770 for an hour without issues [Elektroda, 11922598] Users also report stable operation with G860 + HD6850 [Elektroda, post #11938570]
What protections are built in, and do they work?
Users triggered short-circuit protection; the motherboard died yet the VP-450 shut down safely and survived [Elektroda, p1024, post #11925156] Over-current, over-voltage, and short-circuit protections are listed on Aerocool spec sheets “Aerocool VP Series Datasheet”.
Any known failures or edge cases?
One VP-450 developed a fan growl at idle after roughly seven months of service [Elektroda, 12375587] No other hardware damage was reported.
How to identify which VP-450 revision you have?
Read the label: Andyson build lists 12 V = 336 W; the newer board shows 312 W. Serial stickers differ as well [Elektroda, p1024, post #11925156]
Quick 3-step check: test your PSU’s voltage stability
  1. Connect a multimeter to a spare Molex 12 V and 5 V pin.
  2. Run OCCT power test for 10 minutes.
  3. Ensure readings stay within ±5 % of 12 V / 5 V [Elektroda, swiercm, post #11922218]
Should Aerocool now move from blacklist to whitelist?
Moderators removed it from the “blacklist”, but experts still rank VP-450 as average, not premium [Elektroda, brysiu28, #11938001; finerek123, #11938498]. Future long-term data will decide full whitelist status.
Is Chieftec GPA a better buy than Aerocool VP-450?
Chieftec GPA uses a CWT platform and costs similar money, but some newer units drew “unfavourable opinions” about cost-cutting [Elektroda, swiercm, post #11927069] Choose based on wattage needs and cable length.
