SONOFF SNZB-02D - how to turn on the screen after pairing with Home Assistant?
AoT_Hunter_PL 1035 2
  • Question about re-enabling the SNZB-02D display
    #1 21366220
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Welcome,
    I have paired a humidity and temperature sensor (SONOFF SNZB-02D) in the HA.
    After pairing in MQTT, the device was detected correctly, but the screen on the sensor module itself went blank. I don't know how to re-enable it, and I would like it to display the measurements all the time.
    Before pairing, the sensor had been on the desk for a week and was working fine. :) .
    Is there a power saving function that I don't see in the options?
    Greetings
  • #2 21372067
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Resetting the device helped
  • #3 21393685
    Rate: 12953
    Interesting situation, I tested the same meter and did not have this problem - the screen works all the time.
    I leave the link for posterity:
    Tiny desktop thermometer/hygrometer with display - SNZB-02D - interior and pairing .
    I'm closing this topic because it's solved anyway.
