[Solved] Adjusting New Pear Sensor on 2006 Galaxy 2.0 TDCi Turbo for Error P003A
MarcinTL 3063 3
  • Need for turbo actuator adjustment after sensor replacement
    #1 21376545
    MarcinTL
    Hi. I have a 2006 Galaxy 2.0 TDCi - I have a constant problem with lack of power, error P003A. I dug through probably everything (vacuum, valves , EGR, DPF, the turbine was taken apart - geometry was clean, no locking). In the end it turned out that the copy sensor on the pear had a broken stick, so I replaced it with an original, used, working one and the power problem and the P003A error continued. I bought a new pear, fitted it and now how to adjust it properly? Is it better to disassemble the turbo and send it somewhere for adjustment , or a new turbo? my turbo is in good condition .
    Moderated By CameR:
    Separated from archived topic:
    https://www.elektroda.pl/rtvforum/topic3309511.html
    Reg. 3.1.19 Publishing posts in archive discussions.
  • #2 21388706
    Kamil260396
    Level 4  
    I had a case where the new replacement generated an error and I had to put the original on.
  • #3 21389159
    MarcinTL
    I decided to buy a rebuilt turbine. I set the barbell in such a way that there was no error, the car had a lot more power and drove normally, but the fuel consumption showed me about 15 L per 100 km and the turbine was running at maximum.
  • Flow meter and turbo sensor replacement fixed P003A
    #4 21508888
    MarcinTL
    Hi. It turned out that the cause was a flow meter and a faulty copy sensor on the turbo. There were no errors from the flow meter and the parameter readings were ok, but while driving something strange was happening. I replaced the flow meter with an original and working one, the sensor on the remanufactured turbo was replaced with an original one. The new turbo needed a gentle adjustment on the barb (it was not 4.2 volts) and I replaced the turbo control valve. The car runs like new.
