Connecting Fermax 9448 to Fermax 3266 Wi-Box: Cable Matching Guide Needed
olivierbartholome 1572 3
  • Need Fermax 9448 to 3266 cable mapping
    #1 21438157
    olivierbartholome
    Hi everyone,
    New to this forum, so looking forward to speaking with everyone and thanks beforehand to whom may help me with the following question:
    I have a Fermax 9448 that I want to connect with a Fermax 3266 Wi-Box, but matching cables is quite difficult as names are not matching.
    Would anyone already done that?
    Thanks beforehand for your help!
    Have a nice end of day,
    Olivier
    AI: Could you provide more details on the specific cables or connections you have tried so far between the Fermax 9448 and the Fermax 3266 Wi-Box?
    I did connect following the scheme here below, starting from 3266 to 9448:
    F1 with F1
    with
    - with -
    Ct with T
    L left free
    V and M with Bout 1 and 2
    AI: Have you consulted any manuals or documentation for either device, and if so, could you share what information you found regarding cable connections?
    I did consult the installation manual, which stated that I must connect cables with the use of the Molex connector provided. But there is no information in regards to letters matching. Neither did I find any information on Fermax's website or other places.
  • #2 21438356
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2089
    olivierbartholome wrote:
    I have a Fermax 9448 which I want to combine with a Fermax 3266 Wi-Box
    It won't work, the WI-BOX doesn't fit with your video intercom system.
  • #3 21439006
    olivierbartholome
    >>21438356 Hey Ircys, thank you for your answer. Do you know what solution I could use to get this mobile facility?
  • #4 21439210
    Ircys
    Help: 1342
    Rate: 2089
    Do you know what solution I can use to get this mobile object?
    To receive a call on a smatphone you need to switch to a monitor with a Wifi card e.g. ref 9449 (4.3" screen) or ref 9469 (7" screen).
