Bosch Logixx WVH28420EU Control Module Not Working and PU Mode Issue
ufukHoca 708 2
  • Clarifying that the machine is in service mode
    #1 21531459
    ufukHoca
    Can you please help me? I have a Bosch Logixx Model no: wvh28420eu, we installed a new control module but none of them work. How do I fix pu mode
    AI: Can you describe exactly what happens when you try to use the washing machine with the new control module? Are there any error messages, lights, or sounds?
    no
    AI: What do you mean by "PU mode"? Are you seeing a specific error code or message on the display?
    Service mode
  • #2 21531564
    AsReeX
    Level 40  
    Help: 691
    Rate: 1605
    Module at least programmed under the E-Nr of the device?
  • #3 21531806
    ufukHoca
    >>21531564
    yes
    I messed up the pu mode settings. I need to enter the correct values.
