Remote Desktop Connection: Internal Error on Cellular Network, Office WiFi Ok - Avast & Firewall
czarnyblack 9843 2
  • #1 16686001
    czarnyblack
    Rate: 22
    I have a problem with rdp, namely on the network from the office to wifi, it connects without a problem. However, when I make the Internet access from a cell, an error will appear: Internal error. Free Avast is installed, but I turned it off, the same with the firewall and still no changes.
  • #2 16686028
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    What about "network from the office" - the same network where the RDP server is?
    czarnyblack wrote:
    However, when I make the Internet access from the cell, an error pops up
    OK, and this RDP server issues the service to a public address? Do you run any VPN to reach this server?
  • #3 16686042
    czarnyblack
    Rate: 22
    It is not the same network as in the office. I connect to a completely different location that has a fixed IP address. I do not have a VPN.
    Added after 28 [minutes]:
    Problem solved. On the server to which I connected the Gdata program, the client did not see the connection to Gdata administrator. In other words, the server did not see the server. In the registry I changed the name of the server to IP and it moved. RDP works.
