Smart home hub with camera and touchscreen - Aqara Panel Hub S1 Plus and Camera Hub G5 Pro
(Sponsored) magic9 1647 4
  • Aqara Panel Hub S1 Plus and Camera Hub G5 Pro PoE form a smart home combo that blends wall-mounted control, security monitoring, Zigbee hub functions, and infrared control in one ecosystem.
  • The S1 Plus uses a 4-inch touch display, while the G5 Pro PoE adds Full HD video, local AI face/motion detection, two-way audio, and an IR Blaster.
  • The S1 Plus installs like a classic switch in a standard flush-mounted box with a depth of minimum 40-60 mm and is powered via USB-C.
  • Both devices run through Aqara Home, support Apple HomeKit Secure Video, Google Home, and Amazon Alexa, and can show live camera view directly on the panel.
  • The kit works locally without cloud or subscription, but the panel and camera must share the same LAN for pairing and automation.
  • If you're looking for a way to build a smart home that is not only functional but also aesthetically pleasing - Aqara has the perfect solution for you. The new Aqara Panel Hub S1 Plus combined with the Camera Hub G5 Pro PoE is a duo, Which takes smart home to a new level. In this article we take a look at their features, applications and integration options - everything you need to know before you decide to buy.
    Aqara Panel Hub S1 Plus and Camera Hub G5 Pro PoE boxes on a white surface
    1. What is Aqara and why should you trust it? .
    Aqara is a brand, that has won acclaim from users around the world for its reliable solutions in the field of home automation . It operates based on the popular Zigbee standard, offering compatibility with a wide range of devices and platforms such as Apple HomeKit, Google Home and Amazon Alexa .
    With a wide portfolio of products - from sensors to switches to cameras and touch panels - Aqara allows you to create a cohesive, intelligent home that adapts to the daily needs of the home.
    2. Aqara Panel Hub S1 Plus - smart home management centre .
    2.1 Technical specifications and design
    Panel Hub S1 Plus
    is a modern control centre that combines the function of a classic switch with the capabilities of an advanced home management system. It is equipped with a 4-inch touch display , which allows you to intuitively control all elements of the smart home . Its minimalist design fits perfectly into modern interiors.
    Aqara S1 Plus touchscreen panel mounted on a beige wall in a modern living room
    The panel is flush-mounted - in place of a traditional switch - making it not only functional but also an aesthetically pleasing solution. It supports communication via Zigbee 3.0, Wi-Fi and LAN , which guarantees connection stability and the ability to integrate with a wide range of Aqara devices and more.
    2.2 Features and applications in practice .
    The S1 Plus panel acts as a main home management centre - allows the creation and commissioning of scenarios for automation , e.g.. "Leaving home", "Good night" or "Movie show". The user can control lights, roller blinds, sensors, air conditioning and other devices from the screen.
    The panel also offers thermostat functions - you can create heating schedules and define heat zones in different rooms. This is not only a convenience, but also a real energy saving.
    3. Aqara Camera Hub G5 Pro PoE - security and reliability .
    3.1 Camera hub with Zigbee and IR Blaster functionality
    Aqara Camera Hub G5 Pro PoE is an advanced Full HD IP camera
    that combines up to three functions: monitoring camera, Zigbee control panel and IR remote control - all in a one, compact device .
    With Power over Ethernet (PoE) technology, the camera is powered directly via a network cable , which simultaneously provides stable and fast LAN connection , eliminating the need for Wi-Fi or a separate power supply.
    Surveillance camera mounted on white exterior wall paneling
    The device allows:
    - operate other Zigbee devices , acting as a hub,
    - control traditional household and domestic appliances using the built-in IR Blaster (e.g. TV, air conditioning, audio system),
    - use two-way voice communication (built-in microphone and speaker),
    - detect motion and recognise faces through local AI analysis .
    3.2 Integration with the Aqara ecosystem and other platforms
    The G5 Pro PoE camera
    integrates with the Aqara Home app , as well as with the following systems: Apple HomeKit Secure Video, Google Home and Amazon Alexa. .
    The camera image can be:
    - saved locally (to a microSD card),
    - stored in the cloud (optional),
    - used in HomeKit automations - with notifications to the iPhone.
    Thanks to the LAN connection , the camera works stably even with weak Wi-Fi.
    Adding Zigbee devices is done quickly and without the need for additional bridges..
    G5 Pro PoE can be the main Zigbee hub in smaller systems or support for larger installations with Panel Hub S1 Plus .
    4. How do they work together? - Synergy Panel Hub S1 Plus + G5 Pro .
    The combination of the Hub S1 Plus panel with the G5 Pro PoE camera creates a integrated smart home system .
    G5 Pro is not just a camera - it is also a motion sensor, sound sensor and local face recognition . The camera can recognise a specific household member and send a signal to the panel.
    E.g. when a child comes home:
    → the camera recognises them,
    → the system opens the door (if connected to a lock),
    → raises the roller blinds,
    → turns on lights and music.
    Panel S1 Plus is a touchscreen control centre - allowing you to:
    - display camera images,
    - control lights, roller blinds, climate,
    - activation of scenes,
    - voice communication
    thanks to the microphone and loudspeaker in the camera.
    Example of automation: .
    At night, the camera detects movement → signal goes to the panel → light comes on and Aqara siren is activated.
    This collaboration gives the user a full home management centre that connects:
    - local AI analytics,
    - touch and voice control,
    - security and reliability,
    - flexible automation scenarios.
    5. Step-by-step installation and configuration .
    Despite its advanced technological capabilities, the installation of the Aqara S1 Plus + G5 Pro kit has been designed with the home user in mind - no specialist knowledge or tools are required. The process can be carried out by yourself in a matter of minutes.
    5.1 Assembly of the Hub S1 Plus Panel:
    The Hub S1 Plus Panel
    requires a standard flush-mounted box with a depth of minimum 40-60 mm . It mounts similarly to the classic light switch , making it ideal for both new installations and refurbished premises.
    The device is powered via a USB-C cable , greatly simplifying installation and eliminating the need for a direct connection to the 230 V mains.
    Upon initial commissioning, the panel's automatically displays a unique QR code which must be scanned in the Aqara Home app .. As a result, the process of pairing and integrating with the smart home system takes just a few seconds.
    Wall-mounted Aqara touchscreen panel with Logging in, please wait... message
    The panel connects to the home network via Wi-Fi , which provides stable connection and full functionality of the local Zigbee 3.0 hub .
    5.2 Connecting Camera Hub G5 Pro:
    The Aqara G5 Pro PoE camera
    requires only the connection of an Ethernet cable to the PoE port , which provides power and LAN access in a single cable - without the need for an additional power supply.
    Aqara G5 Pro PoE camera on desk with connected Ethernet cable
    To begin configuration, simply:
    - scan the QR code located on the camera housing using the app Aqara Home ,
    - ensure that the camera and the Panel Hub S1 Plus are connected to the same LAN (via Ethernet or Wi-Fi).
    The process of adding a camera to the system is quick and intuitive and once registered in the app, you can immediately start creating automations, viewing live video and integrating with other Aqara devices.
    Live view from Aqara G5 Pro PoE camera in an office, shown in mobile app
    5.3. Configuration in Aqara Home application: .
    Once devices have been added to an account in the app, the user has access to the full range of functions:
    - creation of automation scenes based on time, sensors, facial recognition,
    - assignment of Zigbee devices to appropriate rooms,
    - scheduling,
    - management of notifications and event history.
    The application is available in Polish and offers a simple, intuitive interface. .
    5.4 Scene creation and integration .
    In the presented case we integrated the G5 Pro camera (PoE) with the Aqara Hub S1 Plus . With this integration, it was not only possible to configure automation (e.g. to enable face detection at the press of a Zigbee button), but also to display the camera view directly on the hub's touch panel . This enables current monitoring of the room without the need to reach for the phone.
    Aqara touchscreen panel displaying live office CCTV feed on the wall
    6. Who is this kit for? Example applications .
    The kit Aqara Panel Hub S1 Plus + Camera Hub G5 Pro will work well in many scenarios:
    - New build: .
    Ideal for homes where a smart home system is planned from scratch. Thanks to flush-mounting and Zigbee communication, it is possible to expand the system without complex wiring.
    - Homes with partial automation: .
    Even if you already have smart light bulbs or blinds, Aqara integrated by panel and camera will allow you to control everything from one place.
    - Small offices and commercial premises:
    Remote camera viewing, lighting control and temperature control also make the system ideal for commercial use.
    The Aqara system is also a great choice for those concerned about aesthetics, data security (local processing) and compatibility with HomeKit, Google and Alexa.
    Aqara Hub panel on beige wall with touchscreen and round dial control
    7. Comparison with other solutions .
    The kit Aqara S1 Plus + G5 Pro PoE is distinguished by local data processing, built-in Zigbee 3.0, IR Blaster and compatibility with HomeKit, Google Home and Alexa . It works without cloud or subscription, which translates into greater reliability and privacy.
    Set Display Zigbee Hub Camera IR Blaster Compatibility Price
    Aqara S1 Plus + G5 Pro PoE 4" touchscreen Yes (Zigbee 3.0) G5 Pro PoE (Full HD, AI, microSD) Yes HomeKit, Google, Alexa 💰💰
    Sonoff NSPanel Pro + CAM Slim 3.5'' No (Wi-Fi only) CAM Slim (RTSP, eWeLink cloud) No Google, Alexa 💰
    Google Nest Hub + Nest Cam Indoor 7" No Nest Cam Indoor (Google cloud) No Google 💰💰💰
    Benefits of Aqara: .
    - Local operation - independence from the internet
    - Zigbee 3.0 in panel and camera
    - Camera with AI and local recording
    - Control of older devices (IR)
    - Compatibility with HomeKit, Google, Alexa
    Aqara smart home set compatible with Apple Home, Alexa, Google, and other platforms.
    8. Summary and opinion .
    is a complete smart home system that combines monitoring, automation and control in a single ecosystem. It works locally, without subscription, and will work well in both new homes and flats.
    Is it worth buying? .
    Definitely yes - especially if you want a complete smart home ecosystem that is easy to expand and does not require subscriptions.
    🔗 You can purchase the Aqara kit from the Official Aqara Store - click here. .
    [Advertising collaboration with BATNA Ltd.]
    magic9
    Editor
    magic9 wrote 1319 posts with rating 519, helped 20 times. Live in city Kielce. Been with us since 2010 year.
  • Zigbee automations still work without Wi-Fi
    #2 21645889
    Rate: 12984
    I like the comparison in point 7. The Zigbee Hub in this kit is really useful. In my opinion, Zigbee is indispensable for battery-powered devices such as various temperature sensors, motion sensors, or door/window openers there.
    I'll also remind you of a cool thing that I discovered myself when testing this kit - namely, automation with a light switch on Zigbee works even when the Wi-Fi is completely turned off. That is, not only does it work locally, it is also immune to, for example, problems with just Wi-Fi....
  • #3 21646164
    TechEkspert
    Editor
    Help: 17
    Rate: 5719
    The panel looks nice, I don't know about the possible heat emission and streak formation on the wall, but this will probably become apparent during use.
    The use of IR in the camera to transmit remote control codes is a new idea.
    I didn't know that Zigbee had already reached version 3.0.
  • #4 21650871
    krzbor
    Help: 43
    Rate: 1073
    magic9 wrote:
    The camera can recognise a particular householder and send a signal to the panel.
    Well, I've just built a circuit that will physically turn off the power to the camera if someone is home - specifically if the alarm is not sounding. It all depends on how you approach privacy.
  • #5 21651068
    TechEkspert
    Editor
    Help: 17
    Rate: 5719
    A good approach, the camera will not consume energy when it is not needed and you minimise the attack vector where the camera would allow you to determine the hours and days of activity of the householders.
TL;DR: Aqara’s S1 Plus + G5 Pro pairs a 4-inch touchscreen hub with a PoE camera-hub, and “automation with a light switch on Zigbee works even when the Wi‑Fi is completely turned off.” [Elektroda, p.kaczmarek2, post #21645889]
Why it matters: You get local-first control, security, and scenes that keep working even if your internet or Wi‑Fi drops—ideal for reliable smart homes.
What is the Aqara Panel Hub S1 Plus?
It’s a flush-mounted 4-inch touchscreen that centralizes smart home control. It includes a local Zigbee 3.0 hub, Wi‑Fi/LAN connectivity, scene launching, and thermostat-style heating schedules. It replaces a traditional wall switch while keeping a minimalist look. [Elektroda, magic9, post #21645786]
What is the Camera Hub G5 Pro PoE and why use PoE?
G5 Pro PoE is a Full HD camera that’s also a Zigbee hub and IR blaster. Power over Ethernet provides power and data through one cable, improving reliability versus Wi‑Fi power adapters. It supports two-way audio, motion detection, and local AI face recognition. [Elektroda, magic9, post #21645786]
Will my automations still work without internet or Wi‑Fi?
Yes. Zigbee scenes continue locally even with Wi‑Fi off. As one tester put it, “automation with a light switch on Zigbee works even when the Wi‑Fi is completely turned off.” This keeps lights and sensors responsive during outages. [Elektroda, p.kaczmarek2, post #21645889]
How do I install and set up the kit?
  1. Mount S1 Plus in a 40–60 mm wall box, power via USB‑C, and scan its QR code in Aqara Home.
  2. Connect G5 Pro to a PoE switch via Ethernet and scan its QR code.
  3. Ensure both join the same LAN, then assign rooms and create scenes in the app. [Elektroda, magic9, post #21645786]
Does it work with Apple HomeKit, Google Home, and Amazon Alexa?
Yes. Both devices integrate with Aqara Home and support Apple HomeKit (including Secure Video for the camera), Google Home, and Amazon Alexa for voice control and routines. [Elektroda, magic9, post #21645786]
What is Zigbee 3.0 in this context?
Zigbee 3.0 is the wireless protocol the hub and camera use to connect sensors, switches, and other devices. It unifies device pairing and enables low-latency, local automations coordinated by S1 Plus and G5 Pro. [Elektroda, magic9, post #21645786]
What is an IR blaster and what can G5 Pro control?
An IR blaster transmits infrared remote codes to legacy gear. G5 Pro’s built-in IR can control TVs, air conditioners, and audio systems that use standard remotes, letting them join your scenes without smart replacements. [Elektroda, magic9, post #21645786]
Is IR control in a camera actually useful?
Yes; placing IR in the camera extends control to non-smart devices near the camera’s field. As one expert observed, “The use of IR in the camera to transmit remote control codes is a new idea.” [Elektroda, TechEkspert, post #21646164]
Can I view the camera on the S1 Plus touchscreen?
Yes. After pairing, you can display the G5 Pro live view directly on the S1 Plus panel and trigger automations from the screen. [Elektroda, magic9, post #21645786]
What privacy options do I have without the cloud?
You can store video locally on microSD and use local AI for motion and face events. The system also integrates with HomeKit Secure Video if you prefer Apple’s flow. No subscription is required for local operation. [Elektroda, magic9, post #21645786]
Can I physically disable the camera when someone is home?
Yes. One user built a circuit to cut camera power when the alarm is off. This reduces energy use and the attack surface that could reveal household activity patterns. [Elektroda, TechEkspert, post #21651068]
Does the panel produce heat or streak walls over time?
Heat and wall streaking are open questions. A tester flagged potential heat emission and streak formation as aspects to monitor during longer use. Plan for ventilation and periodic cleaning. [Elektroda, TechEkspert, post #21646164]
What mounting depth and power do I need for S1 Plus?
Use a standard flush wall box with 40–60 mm depth. The panel powers via USB‑C, simplifying installation and avoiding direct 230 V wiring at the switch. [Elektroda, magic9, post #21645786]
Can the G5 Pro be my only Zigbee hub?
Yes. G5 Pro can operate as the main Zigbee hub in small setups or complement the S1 Plus in larger installs for broader device coverage. [Elektroda, magic9, post #21645786]
How does this compare to Sonoff NSPanel Pro or Google Nest Hub?
Unlike those, Aqara’s combo includes a Zigbee 3.0 hub in both panel and camera, local processing, IR control, and no required subscription. Competitors lean on Wi‑Fi or cloud services and may lack IR or Zigbee. [Elektroda, magic9, post #21645786]
Do I need a subscription or always-on internet?
No. The system works locally, supports microSD recording, and keeps scenes active without internet. Cloud storage remains optional for users who want it. [Elektroda, magic9, post #21645786]
